which gauges to use
Old May 12, 2009 | 10:58 PM
woodyf1's Avatar
woodyf1
which gauges to use
i was wondering which gauges will fit in the original holes can anyone rebuild the originals for 12 volt opinions thanx
Old May 13, 2009 | 12:30 AM
Old F1's Avatar
Old F1
Old May 13, 2009 | 12:42 AM
mostly52f1's Avatar
mostly52f1
found on ebay...
i like these the best...
Old May 13, 2009 | 01:39 AM
Julies Cool F1's Avatar
Julies Cool F1
Sure, you can - and it's easy.
There's three ways to go here: You can buy the nice looking new gauges the guys pictured in the clusters above; you can convert your stock oil pressure and temp to mechanical gauges and use a voltage reducer for the gas gauge; or you can convert your stock 6 volt electric gauges to 12 volt by installing the reducer on the back of three of them (gas/oil/temp - amps is a simple induction loop that needs no conversion it will work as is with 12 volts but when switching to negative ground, you will need to reverse the flow direction of the wire).
I have a gallery that shows how to convert the oil and temp to mechanical gauges. There is a MS document I wrote that has the provedure spelled out. If you are interested, send me a PM with your real e-mail and I'll send it to you. it's fairly simple - involves a little trimming of the cases but still very straightforward.
For the last option, all you would do it install three little voltage reducers on the backs of the stock gauges. These guys cost about $20 and you will need 3 of them. It's very easy to do.
I think Mid Fifties sells a one shot package that converts all the gauges with a single unit, but I have heard it gets very hot. I converted my oil/temps to mechanical and used the reducer on the gas gauge - it works perfect!
Here's a picture with a part number for the reducer from the C&G catalogue:
Name:  Gauge Voltage Reducer.jpg
Good luck!
tjdad62
Jan 22, 2013 05:16 AM
ola1234
Sep 30, 2012 10:40 PM
imlowr2
Jun 9, 2007 09:57 PM
NormH
Mar 21, 2007 11:59 AM
jaymorris
Jan 31, 2007 06:25 PM
