weird HPOP o-ring situation
Old May 12, 2009 | 11:38 PM
guzzle92's Avatar
guzzle92
The oil rail is the channel that runs the lengh of the cylinder head. Each head has 4 plugs next to the valley and one plug on each end of the head. The ICP on the driver's side screws into one of the oil rail ports.
Old May 12, 2009 | 11:45 PM
tnardo's Avatar
tnardo
just got something that hadnt been kept up with and i put on a ton of miles, i usualy do all my own work, just been too busy to do so..... not this time though, i took it to the ford truck center last time, hoping that the big money investment would get her upto shape for a good while, guess not, so now ill take the time to do it myself and do it right
Old May 12, 2009 | 11:46 PM
tnardo's Avatar
tnardo
so these oil rail plugs tend to leak....
Old May 12, 2009 | 11:49 PM
Tenn01PSD350's Avatar
Tenn01PSD350
You are in the right place for help there. I learn new things just about every day. Even from new folks.
Tenn01PSD350
No, they do not.
Old May 12, 2009 | 11:50 PM
guzzle92's Avatar
guzzle92
Not so much but any connector on the engine CAN develop a leak. You just need to catch it early and be prepared to fix it.
Old May 12, 2009 | 11:53 PM
tnardo's Avatar
tnardo
thats why i ordered the entire kit.....
Old May 12, 2009 | 11:56 PM
tnardo's Avatar
tnardo
what does icp stand for?
Old May 13, 2009 | 12:04 AM
tnardo's Avatar
tnardo
well im off to bed, thanks for your help guys.
honestly i dont feel that ive nailed down this leak yet, but i have elimanted a lot of possibilities and will have the peace of mind of knowing exactly what is new.... and a new WW, foil delete, and im gunna do the CCV also. oh yeah also cleaning the ebps tube, praying for better mpg
onto tommrow....
Old May 13, 2009 | 12:15 AM
Tenn01PSD350
Injector control pressure. It is what fuels our trucks. Without it, the truck wil not start or run. It is a reading of the oil pressure in the high pressure oil system. This high pressure oil forces a plunger in the injectors to inject fuel into the cylinders.
Old May 13, 2009 | 12:16 AM
tnardo's Avatar
tnardo
thats what i thought,,,, so its the injector control pressure sensor
Old May 13, 2009 | 12:19 AM
Tenn01PSD350
There is a injector control pressure sensor or ICP. Is that where your leak is?
Old May 13, 2009 | 12:21 AM
  #28
tnardo's Avatar
tnardo
doubtful, driver side was pretty clean, but we'll have a closer look tommorow.
Old May 13, 2009 | 12:23 AM
  #29
Tenn01PSD350
Keep us posted. We can help most folks fix 99% of what happens to these trucks. Stay with it bro. Someone has seen your problem before and fixed it.
Old May 15, 2009 | 07:26 PM
  #30
tnardo's Avatar
tnardo
ok, i'm back, truck went back together great, ccv mod and foil delete complete. took me all day and 2 broken filter wrenches to do the oil change, i have never had a filter that difficult, and ive done a lot, ended up cutting it a part and using my air hammer in the oil holes up top to spin it off.
WW and foil delete sound awesome!
still leaking oil, right where i said it was, out of the fitting going into the pass head, or maybe the inner oring on the fitting, either way i need those orings and i dont have em... but it'll only take a few minutes to do... guzzle r ya open and shipping out, on saturdays, ps now you've heard of them leaking
