Sponsored by: Auxito
noise in back
Old May 12, 2009 | 02:47 PM
Ali88's Avatar
Ali88
noise in back
I have a noise in the rear of my 2000 f150, it sounds like a flat tire but it isn't, anybody know what else may cause this?
Old May 12, 2009 | 03:18 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE Ali88! You might want to have the rear differential checked, bearings, seals and fluid level. Good luck!
Old May 12, 2009 | 05:52 PM
firefighter1416's Avatar
firefighter1416
does it do it when you turn.......??? it could be the clutches chattering in the limited slip, they say you can add a bottle of friction modifier to fix this IMO it does not work, or at least it didn't for me. i had my hog tore down and the clutches buffed this fixed it. Hope this helps
