Sponsored by: Auxito
only have high air
Old Apr 25, 2009 | 09:50 AM
guitarking135's Avatar
guitarking135
only have high air
so I replaced my blower motor cause i wasn't getting anything now all I get is high. what is the most likely culprit to this? the switch relays? or is it something I'm better off to take to a mechanic and to save me time and possibly money?
Old Apr 25, 2009 | 09:54 AM
guitarking135
also its a 2002 with the 5.4 4x4 and everything else on the climate controller works it just doesn't have low or medium blowing
Old Apr 25, 2009 | 10:32 AM
projectSHO89's Avatar
projectSHO89
Go to the HVAC section and see the FAQs.
Your FAQ is answered there.
Old May 12, 2009 | 02:37 PM
Ali88's Avatar
Ali88
It sounds like it's your resistor, it's under the dash on the passenger side
Old May 12, 2009 | 05:59 PM
steve(ill)'s Avatar
steve(ill)
there is a resistor block about 2 inch square screwed to the air duct under the glove box area???? should have a 4 wire harness plugged into it. has a how wire inlet and 3 wires (speeds) out. if the resistors fail, you got only hi. should be able to buy at Auto Zone.
