Hitches???
Old May 12, 2009 | 02:04 PM
DawallzSTX09's Avatar
DawallzSTX09
Hitches???
hi everyone, newbie here from Florida. I wanted to ask all you '09 owners if you have a hitch or are considering one where would you get it from. And is it easier to put it on yourself or have someone do it instead. Also will they hitch that is sold @ wally world fit the newer 09. I've got a F-150 STX X-cab that my husband bought me. Any info will help. thanks!!!
Old May 12, 2009 | 03:37 PM
04XLTRUNNER's Avatar
04XLTRUNNER
i would go with the factory hitch. or u-haul should have one. very easy to put on
Old May 12, 2009 | 06:00 PM
hitchman's Avatar
hitchman
Please do not get one of the multi fits from any retailer. Get a custom one piece no drill and you can install it yourself or have someone do it for you.
Old May 12, 2009 | 07:43 PM
DawallzSTX09
where is good place to get one from. i hear u-haul is good, is there specific brand that you may recommend.
Old May 12, 2009 | 08:46 PM
hitchman's Avatar
hitchman
U-Haul should be fine, most towns have what I call a "pro installer". If you let me know your location I can probably recommend someone, in many places U-Haul is the Pro Installer. Since I like to see the commerce members on here supported I will not post a brand or installer on the forum, only via PM. I hope that answer does not get me in forum trouble.
Old May 12, 2009 | 08:51 PM
DawallzSTX09
on problem, not looking to get people in trouble. I live in west palm beach,fl.
Old May 12, 2009 | 09:24 PM
idaho_steve's Avatar
idaho_steve
etrailer.com is a great source and has front and rear bolt-on hitches that fit the '09's. It takes about 30min or so to do. (It helps if you have a floor jack available and/or a couple of buddies to help hold it in place while you get it started.) I've used them for years. Steve
Old May 12, 2009 | 09:35 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
U-haul is a pretty good source.
they do a good job usually, and the hitches they install are all bolt-in. They don't do anything custom wise to make it fit.
Old May 12, 2009 | 09:45 PM
Greg B's Avatar
Greg B
Most anyplace that sells trailers, travel trailers, or trailer parts and supplies retailer can sell and install if necessary a proper hitch on your truck. And they'll be cheaper than your local Ford store. You just need to check the yellow pages in your area. Reese, Draw-Tite, and Hidden Hitch are all good quality names. Just make sure you get a Class IV hitch made for your truck so that there is no drilling involved. It makes the install easier. It's always easier to have someone else do the work.
Tnriverside
Aug 29, 2017 12:17 AM
kylant
Jul 7, 2017 08:44 AM
AzBlueOval
6.7L Power Stroke Diesel
15
Feb 16, 2016 05:45 PM
4bigred
Oct 8, 2015 08:00 AM
Cable Guy
May 21, 2012 01:01 AM
