Sponsored by: Real Truck
Is 4x4 working ?
Old May 13, 2009 | 12:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by EXv10
Any discrepancy beween the front and rear wheels on a turn will be absorbed by the the open differentials ability to allow for varying wheel speeds.
Not true. The Superduty and Excursion transfer case is fully locked in 4x4, and has no internal differential.
Old May 13, 2009 | 12:42 PM
bpounds's Avatar
bpounds
Right! If anyone doesn't believe it, try driving in 4WD on hard pavement - and learn the hard way. (don't do it)
Old May 13, 2009 | 06:09 PM
EXv10's Avatar
EXv10
I never said the t-case had a differential. All wheels act like a 2 wheel drive truck while locked in 4wd other the the u-joints as far as turning goes . Case closed for me on this.
Old May 13, 2009 | 06:12 PM
EXv10's Avatar
EXv10
And that is because of the u-joints. I guess you guys aren't reading closely.............case closed for me.
Old May 13, 2009 | 10:13 PM
EXv10's Avatar
EXv10
not true, not true, not true.................
Old May 14, 2009 | 11:49 AM
krewat's Avatar
krewat
The way you said it, it sounded like that's what you meant.
And even if you didn't, what you said is NOT TRUE.
The front and rear differentials can not take up the difference between the front and rear wheels going around a turn.
Old May 14, 2009 | 12:03 PM
Downriver Thunder's Avatar
Downriver Thunder
Is the case closed for you? I'm not sure on this one.
Old May 14, 2009 | 03:35 PM
EXv10's Avatar
EXv10
Old May 17, 2009 | 02:27 AM
EXv10's Avatar
EXv10
Case re-opened
After doing some research I see that you guys are right about the rear wheels and the front ones not turning the same RPMs on a turn. They do not follow exactly the same arc and this is why some or all of the all wheel drive cars have some type of differential between the front and the back wheels. Mouse over green light to see demo......... Sucks to be wrong
HowStuffWorks "How Differentials Work"
Old May 17, 2009 | 08:26 AM
bpounds's Avatar
bpounds
Gentlemanly of you to come back and say so. And it helps close the case for everyone. Thanks.
Old May 17, 2009 | 11:17 AM
krewat's Avatar
krewat
Rep points for coming back and letting us know
Old May 17, 2009 | 02:24 PM
bohiaa's Avatar
bohiaa
ok update:
it seems that I was right and wrong. " and it looks like yall took the post and went WaCk0 "
when I tried it I was NOT in 4 wheel drv, even though the dash light said I was. it seems that there is a vac leak, somewhere or it takes MINE a few trys to get into 4 wheel drv.
however while in 4 wheel I was a bit surprised that the rear wheels would spin, " almost like NOT in 4X4 " on a gravel road. I own a landscaping co. and with the trailer connected and about 2 tons. is when I was testing it.
I figured that the front wheels would spin before the rear ones would.
I did get that. bucking and hard to steer while in 4x4.
once again thanks for everyone's reply, and I hope we all learned something.
I know I did
Old May 17, 2009 | 02:36 PM
  #28
EXv10's Avatar
EXv10
Front and back are probably both spinning on one side but you don't realize it, (if you are locked in the front). Last winter I was on some ice on a back road and I thought I wasn't engaged in the front but it was so slippery I couldn't tell. (open diff). That's why I say that you can get on a gravel road, step on the brake and the gas, spin the tires for 5 feet and get out to look at the tracks or you can have some watch your front wheels for you as they spin (or don't).
mt.dave
1997 - 2003 F150
Nov 20, 2012 11:32 AM
shoobear
Apr 11, 2010 07:32 PM
Kalashtar
Jan 29, 2006 02:32 PM
amw_drizz
1978 - 1996 Big Bronco
Mar 2, 2005 08:16 PM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
