Front differential fluid...
Old May 12, 2009 | 10:37 AM
MrDumass's Avatar
MrDumass
Had my 06' XLT 4x4 Screw with 36,500 on the clock in for an oil change yesterday. They called me and said the front differential fluid was milky and needed replaced. No big deal, go ahead and replace it, right? Well, it got me wondering what would have caused this? I thought it wouldnt need replaced for quite some time. I'm the second owner, but the truck is immaculate inside and out. Anyway, I was just wanting to get some thoughts on this, and see if anyone else has had the same issue? Maybe get some ideas on what caused it. Thanks in advance!
Old May 12, 2009 | 11:20 AM
CCBennett_1's Avatar
CCBennett_1
Most likely I am wrong on this but could this be caused by water getting inside and contaminating the fluid?
CCB
Old May 12, 2009 | 11:28 AM
MrDumass's Avatar
MrDumass
CCB
Thats what I was thinking, but didnt know how this might happen. I would think it would take quite a bit of playing in water to make that happen. Maybe I'm wrong? Maybe it was tainted from the factory? Maybe it was replaced with something bad? Maybe it has something leaking into it, but what? I was just kind of wondering what others had expierenced, if anything.
Old May 12, 2009 | 11:41 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
that milky substance is actually very normal for these trucks...general consensus is that it is assembly lube mixed in with the diff fluid.
the front axle never really gets turned, so it seperates...and looks like water
it obviosly won't do any harm to change out...and ask your mechanic to save the fluid. let it sit in a bucket. if water, you'll see it seperate and the diff fluid will sit on top, and any water will be under it all in the bottom of the bucket.
btw, check your axle breather hose just in case
Old May 12, 2009 | 11:44 AM
MrDumass's Avatar
MrDumass
tylus...thanks a lot!
ExPACamper
59
May 4, 2017 09:39 AM
jefft29
Feb 2, 2017 12:52 PM
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 3, 2016 09:22 PM
dziskovs
2009 - 2014 F150
Apr 28, 2016 08:11 PM
63' f100
May 25, 2010 08:38 AM
