Differential Fluid ?
Old Aug 12, 2002 | 11:10 AM
Luis_3's Avatar
Luis_3
I need to check levels of mi differentials but I need info about which fluid should I buy. I came to store and requested for fluid, but they were giving me Transmission FLuid. is the same fluid from ATF to differential??
Old Aug 12, 2002 | 11:55 AM
jimandmandy's Avatar
jimandmandy
Post Differential Fluid ?
Unless they are leaking, you shouldn't need to add any. Any name-brand 80W-90 GL-5 lube should work. Ford specifies "4x4 Gear Oil" for the Dana 44 front and "Premium Rear Axle Lubricant" for the Ford 8.8 rear. Ford specs and part numbers are listed, but no practical information as to what to buy. This information is from the shop manual. If you have an owner's manual, there might be better information there.
Jim
Old Aug 12, 2002 | 11:58 AM
jim henderson's Avatar
jim henderson
daveplot
Jun 27, 2011 12:05 PM
bigdog194
Nov 30, 2010 07:53 AM
Vijay
24
Oct 19, 2009 01:54 PM
Dre82s
Feb 15, 2007 08:27 PM
carpe_diem
Jun 6, 2003 10:44 AM
