E-350 issues?
Old May 11, 2009 | 02:28 PM
stevo250xc's Avatar
stevo250xc
E-350 issues?
I'm considering purchasing a 1984 E-350 camper van (Vangaurd Converstion) but know very little about this chassis or motor. Can any one pass on what to look out for in this configuration,. I'm pretty sure its a 460 and a C-6?. 138,000kms only but has been sitting for the last 1.5 years.
Thanks,
Steve
Old May 11, 2009 | 07:48 PM
kenjh's Avatar
kenjh
if the price is good ..spend the bucks to get an inspection done for about a hundred bucks you get a lot more info then we can give here..,that said i have had 2 vangaurd camper .check for leaks in the roof in the corners.run up all the appliances, the can be expensive to repair or replace..and ask how often they used it and who maintained it..the are pretty good units if they are taken care of
Old May 12, 2009 | 12:15 PM
stevo250xc's Avatar
stevo250xc
Thanks Kenjh. I whent there last night to start it up, it runs fine for 30 seconds or so and then dies. Any sugestions? I was unable to find a fuel filter to sawp out incase its dirty.
It doesnt feel like the typical clogged line though because it runs as though it only has a set few ounces of gas each time to run on, regardless of the Rev's you hold. It still dies if I let it idle and not Rev it, it just take a little longer.
Old May 12, 2009 | 09:40 PM
kenjh's Avatar
kenjh
ok is it carberated or fuel injected? if you crank it over will it start again??or do you have to wait?can youhear the fuel pump? they pressurize the system then go silent when they have pressure up
Old May 12, 2009 | 09:49 PM
kenjh's Avatar
kenjh
dumm question what does the fuel guage read?
Old May 14, 2009 | 07:42 AM
2000Ford2000's Avatar
2000Ford2000
That's going to be carburated. Those can be a lot of trouble. Probably needs the carb rebuilt if it hasn't been done in a few year.
Old May 15, 2009 | 02:25 PM
rebocardo's Avatar
rebocardo
Could be the carb., very likely the fuel is bad. They go bad after sitting for a while.
Old May 16, 2009 | 12:11 AM
kenjh's Avatar
kenjh
well if it carbed disconnect the fuel line to the carb an run it into a 2 liter jug and crank it over this way you will see what you are feeding the carb if it stinks fresh gas might cure it .running for 30 seconds makes me think the float valve is sticking .purging some of the old gas will help..the pump should move a fair bit of gas even just cranking if it doesn't it might just be the fuel pump is tired.....so ...how are you doing??
Old May 16, 2009 | 08:24 AM
rebocardo's Avatar
rebocardo
I meant to write "very likely the fuel PUMP is bad"
Old May 16, 2009 | 10:28 PM
FloydinTampa's Avatar
FloydinTampa
Originally Posted by kenjh
well if it carbed disconnect the fuel line to the carb an run it into a 2 liter jug and crank it over...
I tried that once and it fired up, started filling the jug as the engine ran, and then when the carb had used up the fuel that was in the bowl the engine backfired and started the jug and the disconnected fuel line on fire. Luckily, there was a hose nearby and there wasn't any damage, but it sure woke me up.
You need to disable the high-voltage part of the ignition system if you are going to crank the engine with a fuel line open. I would suggest that pulling the coil wire isn't enough to prevent a spark, but maybe it is. It might be better to disconnect the +12v line on the coil and secure it so that it can't arc.
Old May 17, 2009 | 12:24 PM
trucker101's Avatar
trucker101
same problem different post
Definitely pull off the slide on piece on the coil to remove the sparking power of the coil before cranking it over with the fuel line open. You may want to read the other postings & questions that I started>> here <<. I'm having the same problems as you,I think I've tracked it down to the inertia switch.
Old May 17, 2009 | 08:46 PM
kenjh's Avatar
kenjh
would an 84 van have a inertia switch??.and yes I forgot to mention the coil disconnect,sorry about that!!
Old May 17, 2009 | 10:12 PM
trucker101's Avatar
trucker101
would an 84 van have a inertia switch??.<snip>
I'm not sure if it does or not,but lucky me I have an 85 with one.
Old May 17, 2009 | 10:14 PM
trucker101's Avatar
trucker101
(cut & snip)
