Ignition not shutting off
Did you check to see if you had 12volts to the solenoid before you replaced 2 of them for nothing? Is the solenoid hooked up correctly?
Does it still crank with the ignition wire disconnected from it?
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
By | 2026-05-18 19:34:33
By | 2026-05-18 19:26:42
By | 2026-05-18 19:20:37
By | 2026-05-12 18:07:46
By | 2026-05-12 13:09:47
