Aerostar Ford Aerostar
Servo Help
Old May 9, 2009 | 08:04 AM
CdnSoldier's Avatar
CdnSoldier
Servo Help
I posted this over on the Trannie forum, but no reply so Im trying hee. Is there any differance between a Piston casting # 7T/83DT-7E221-A1A and a Piston casting # 7T/83DT-7E221-A2A) I the org one I had was a A2A but had a damaged lip. I replaced it with a A1A. Now I have no Rev, or 1,2 or in D. Any thoughts?
Old May 9, 2009 | 10:03 AM
Pablo-UA's Avatar
Pablo-UA
Try Ranger forum. They may know.
well, do they look similary. I remember when I had a4ld I had this problem... I do not really remember how this problem was solved (it was many years ago). Anyway, I sold my A4LD and now I have 5st tranny... finally ready to fail (nocks a bit)
Old May 9, 2009 | 10:42 AM
96_4wdr's Avatar
96_4wdr
same part. the largest OD servos avail in A4LD, 4R series
A4LD Transmission Parts Servos & Accumulators Makco Transmission Parts
# A56902AG Piston, Intermediate / OD servo, C3 / A4LD / 4R44E / 4R55E
Servo # AA / AB, 2.075 inch ID cover (Piston casting # 7T/83DT-7E221-A1A/A2A)
is the piston leaking by? new replacement?
Old May 9, 2009 | 12:29 PM
xlt4wd90's Avatar
xlt4wd90
Have you measured the dimensions of both parts?
Old May 9, 2009 | 03:06 PM
fordnut71's Avatar
fordnut71
put in a AB servo for Intermeaten an a ZC servo on the overdrive. its the biggest servos you can get for the A4LD.
Old May 10, 2009 | 04:33 PM
CdnSoldier's Avatar
CdnSoldier
Thanks
They are both the same size, but for some reason the trannie shop does not list a conversion. I put in the old one and every thing is great. The cap does not have any letters to give which one is which. ie AB,BB,AC etc. And the trannie shops only two here, dont really like to do Fords. I may just order two complete Servos and Caps.
I really liked my old C6 and FMX trannies with my old Mustang and T Bird. S easy to rebiuld and fix.
Old May 10, 2009 | 08:08 PM
fordnut71's Avatar
fordnut71
they wont list a conversion. they are for the 5r55e, its what they use. an seeing the c3,a4ld an 5r55e tranny are really all the same tranny you can get the 5r55e servos to replace the a4ld.
so find a tranny shop or rebuilder an ask for the zc cover an servo,you already have the ab cover on the a4ld.if you ask around an bug them a few times they will probley tell you who they buy there used hard parts from.
sfu7274456
All Other Items for Sale
Mar 19, 2017 10:23 AM
BGF100
Mar 1, 2017 08:59 PM
sandymane
19
Dec 29, 2016 04:15 PM
deshet1980
Large Truck
Sep 11, 2015 08:48 PM
wirelessengineer
May 17, 2015 05:28 PM
