any "benign" check engine lights?
Old May 8, 2009 | 11:05 PM
vatreefarmer's Avatar
vatreefarmer
I was towing my bassboat home today in tow/haul mode. About 1 hour from home the service engine light came on. All guages were WNL, as was turbo. No message came up on the display. Truck seemed to operate just fine, but obviously this made me overly aware of every little perceived change in performance. It just turned 45,000 miles. Oil level was fine, fuel filters were changed 5 months ago Coolant OK with no puking. I will take her to the dealer ASAP to discover the cause, but its the weekend and may be Wednesday before I can get her in. Just to put my mind at ease, are there any stupid triggers for that light, such as "due for 45,000 mile service" or something like that? Any insight y'all have that I can check with no mechanical skills? Thanks!!!!
2006 f-250 6.0 (All stock, no tuner)
Old May 9, 2009 | 06:51 AM
bismic's Avatar
bismic
When did you buy the truck? If it was after July 14, 2006 you have a complimentary 60k PowerTrain warranty (FYI).
Old May 9, 2009 | 07:40 AM
riggz's Avatar
riggz
No, the light shouldn't come on for a 45k mile service reminder. Is it still on when you start the truck today?
Old May 9, 2009 | 09:17 AM
vatreefarmer
Yes, the light is still on
Old May 9, 2009 | 09:30 AM
vatreefarmer
I bought it used with 20k miles, i think it was put in service in March '06
Old May 9, 2009 | 10:04 AM
vatreefarmer
Just for some more information:
I had the "message center" run through it's scans and all checks out OK (coolant temp, oil level, air filter, etc)
I also looked at the transmission fluid, shows nice red color on the stick, no burnt smell, although the level looks a little high since it shows full on the "H" side of the stick and the truck is cool.
Old May 9, 2009 | 10:50 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Take it to AutoZone for a free CEL scan. Let us know the code that pops up.
Old May 9, 2009 | 11:40 AM
vatreefarmer
Great idea! The scan shows code P0261 "injector circuit low" for every cylinder. Their printout says possible causes are possibly:
1) open circuit condition
2) coil to coil short
3) FICM poor connection
4) Faulty fuel injector
I doubt if I lost all 8 injectors, so I guessing it's either fuel pressure fault or FICM, but then again, I'm an idiot. Truck seems to drive fine. Should it be OK to drive for the next few days until I can get it in to the dealer? Should this issue be covered under 10yr/100K warranty?
Old May 9, 2009 | 12:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yes, should be okay.... did they RESET the CEL or no? If so, did it come back on?
Old May 9, 2009 | 12:48 PM
vatreefarmer
I asked them not to reset it so the the dealership could see it. Do you also suspect the FICM and is that warrantable?
Old May 9, 2009 | 01:47 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yes, it is under the 100,000 warranty....I'll leave the diagnosing to the Ford people.
Old May 9, 2009 | 06:26 PM
Sarge261's Avatar
Sarge261
I would say that I am almost 98% positive that its the FICM, and lucky for you its not only covered under warranty but you will get the newest version.
You will just have to pay the 100.00 deductable.
Good Luck,
Sarge
Old May 9, 2009 | 10:07 PM
vatreefarmer
Thqt would be great news. I wonder if thet will reset the code and make it re-appear before replacing it. I really don't want any surprises and would be willing to pay a little more to remove any concerns about a recurrence
Old May 10, 2009 | 06:23 PM
Sarge261's Avatar
Sarge261
Dont reset the code before brining it to the dealer. If you do they wont see it and they will say there is nothing wrong with it and you will be out 100.00, so just make the appointment and get it fixed, even if thats not it thats what waranties are for.
Sarge
Old May 10, 2009 | 09:51 PM
riggz's Avatar
riggz
Also make sure the connection is good at the FICM. I've heard of them coming loose.
