Oil & Lubrication
"rejoin" amsoil?
Old May 8, 2009 | 10:54 PM
rsylvstr's Avatar
rsylvstr
"rejoin" amsoil?
I'm getting ready to do the rear end (again - leaking) and drop the AT pan/filter (and install a drain bolt)....I joined Amsoil previously so i could get the wholesale prices, but never followed up to become permanent or whatever. So am i screwed and have to pay retail now?
Old May 9, 2009 | 10:13 AM
89Flivver's Avatar
89Flivver
not really.
I "stock pile" filers, oils, lubes. Save mucho dinero that way. I do a 6 month membership via an excellent wholesaler, buy everything I may need for 2 years, then go quiet and let the membership lapse. This way the dedicated wholesaler gets the much needed credit, and I get the great prices.
One big advantage is that I have a Studebaker manual Transmission. That is GL4 land, but with the exception of Amsoil, everyone else wants to tout "trust us" GL4/5 combos.
My wholesaler, who has always gone the extra kilometer is:
http://pws.cablespeed.com/~pablomail...esfilters.html
Work with "Pablo", you will be happy
As for cost, in the same quality grade, Amsoil, including shipping falls about in the middle of the pack compared to going to a big box store costs including taxes (IF you can get the specialty fluid.) On filters, Amsoil cost near the top of the pack. And you better believe that is controversial.
Old May 9, 2009 | 10:19 AM
rsylvstr's Avatar
rsylvstr
Originally Posted by 89Flivver
not really.
AMSOIL PRODUCTS
i've worked with Pablo before. fought with Amsoil corporate to get my account changed to him, hope that worked. i joined about 28 months ago, but didn't stockpile like i had planned....well, i did, but used it all. so now it sounds like my only option is to get a hold of him and order some ATF.
I just saw this on his site, thoguht it was a one time shot: "Preferred Customer memberships may be renewed indefinitely for only $20/year."
and now i see they have a 6 month for $10...i think that's new. thanks for the reminder!
now i have to figure out how many quarts it'll take for a AT pan drop/filter change and a few drain and fills over the next year.
Old May 11, 2009 | 08:59 AM
jimandmandy's Avatar
jimandmandy
There is endless heated debate on this subject in the old VW community. What Amsoil product is GL4 only? I use Sta-Lube GL-4 gear oil from NAPA in the Karmann Ghia transaxle. Pennzoil supposedly makes one, but no distributor in this state apparently stocks it. For those that are reading this and dont know what we are talking about, GL-5 and GL-5/MT-1 gear lubes have so much sulfur-based (that is the gear oil "stink") extreme pressure additive that brass or bronze parts in some older manual transmissions can be corroded by it. GL-4 is a "milder" formula, not suitable for high offset hypoid gears found in Dana or Ford/Sterling differentials. VW used spiral bevel gears, like in 1940's Fords.
I prefer Redline when it comes to synthetics, and the MT-90 product would be perfect, except the old VW seeps trans oil, rebuilding just to replace seals is too big of a PITA, and no matter what they say, synthetic lubes do leak out faster if there are already bad seals.
Jim
Old May 15, 2009 | 09:30 AM
89Flivver's Avatar
89Flivver
Originally Posted by jimandmandy
There is endless heated debate on this subject in the old VW community. What Amsoil product is GL4 only?...
Jim
Pablo, see above, found it for me. The bottle literally says "Manual Transmission"
Old May 15, 2009 | 10:02 AM
jimandmandy
Redline also has such a product, MTL or Manual Transmission Lube, that is GL-4 only.
Jim
