cab swap
Old May 8, 2009 | 10:48 PM
f150onblocks's Avatar
f150onblocks
cab swap
I'm getting a 77 f150 and a crew cab to put on it. The frame is set up for a standard cab, but I'm thinking I can just add the extra frame mounts and to compensate for the frame jumping up over the axle, I will just use a body lift with the rear ones cut down to size. Am I correct on this or completely wrong? Thanks in advance
