Problem solved! No more wheel jerking back and forth.
Old May 8, 2009 | 09:34 PM
EXv10's Avatar
EXv10
If you look at the post below you will see that this has been a long drawn out problem. I discovered there were 2 nuts missing on the front of my right knuckle which caused the wheel hub to be out of alignment with the knuckle. Someone left them off a year ago in a shop 1,000 miles away when they put the BJs in. I almost started replacing parts but discovered it when my right hub wouldn't go back on after greasing it.
https://www.ford-trucks.com/forums/8...ml#post7258745
EXv10
Nov 5, 2021 11:09 AM
sillyjt
Dec 6, 2011 09:19 PM
brian Felts
Aug 30, 2011 11:23 PM
EXv10
May 9, 2009 08:30 PM
wptski
Dec 29, 2002 09:13 PM
