2000 Expo - weird driveability problem
Old May 18, 2009 | 12:28 AM
pinellas50's Avatar
pinellas50
I'm about 15 minutes South of Clearwater in Seminole. Anywhooooo.
I found this information while searching the AWD system:
Check out this little tidbit from my manual, maybe it'll shed some light:
Transfer Case — Automatic Four- Wheel Drive (A4WD)
Features and Operation
The automatic four- wheel drive (A4WD) transfer case uses an electronic shift 4x4 system that allows the operator to choose between three different 4x4 modes. The operator can switch between A4WD and 4WD HIGH modes at any speed. However, to engage or disengage LOW Range, the GEM requires that the vehicle speed is less than 5 km/h (3 mph), the brake is applied, and the transmission is in NEUTRAL.
In A4WD, the generic electronic module (GEM) varies the torque split between front and rear drivelines by controlling the transfer case clutch. Under most conditions, the GEM activates the transfer case clutch at a minimum duty cycle (percentage of time the clutch is turned on) which allows for a slight speed difference between the front and rear driveshafts which normally occurs when negotiating a corner on dry pavement. When the rear wheels are overpowered, the GEM detects this slip condition, and the duty cycle to the transfer case clutch is increased until the speed difference between driveshafts is reduced. In this manner, the GEM can redirect engine torque to the front wheels when the rear wheels lose traction yet still allow operation in the A4WD mode on dry pavement.
When the ABS system is active, the GEM will default to a minimum duty cycle for the transfer case clutch.
Feature Inputs:
Shift range selector switch.
Front and rear output shaft speed sensors (Hall effect sensor output: 11.86 Hz/km/h).
ABS active input (battery voltage when ABS is active, grounded when inactive).
Contact plate position inputs A, B, C, D grounded when closed, open circuit when open.
Feature Outputs:
Solid state clutch relay (pulse width modulated signal: grounded when relay is on, battery potential when relay is off).
Shifting Between A4WD and 4WD HIGH
The operator can switch between A4WD and 4WD HIGH mode at any speed.
Shifting Into/Out of LOW RANGE
When shifting into or out of LOW RANGE, the GEM requires that the vehicle speed is less than 5 km/h (3 mph), the brake is applied, and the transmission is in NEUTRAL.
It was in this thread: https://www.ford-trucks.com/forums/1...ition-4x4.html
So I don't know if your problem might be in all that or not. As I was saying before, I recognized the symptoms as they would apply to that God forsaken pile they call a Typhoon. Good luck with it.
Old May 18, 2009 | 10:41 AM
wattsk69's Avatar
wattsk69
Trailering
I'm taking it to a 4wd mechanic early this week. I'm afraid to let it get any worse, ie= expensive. I'll post the problem and solution as soon as I find out.
thanks again!
Camalot
Dec 10, 2013 10:51 AM
mzender
2004 - 2008 F150
Jan 24, 2013 04:37 PM
FordMaverickFan
May 24, 2012 09:03 PM
evopete
May 7, 2011 05:56 PM
BroncoPimp94
Feb 9, 2010 06:45 PM
