rough running
Old May 8, 2009 | 09:23 AM
bkoon's Avatar
bkoon
rough running
i have a rather large problem. my truck runs fine if you take it easy on it but if you get down on it it seems to run rough .take your foot off the fuel it smoothes out. i have changed the filter and switch. Any help would be very helpful
Old May 8, 2009 | 05:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE!!!!!
Does it smoke when your foots in it? What color smoke if it does?
Old May 8, 2009 | 05:47 PM
Action4478's Avatar
Action4478
How old & what type of oil are you running ?...
Old May 9, 2009 | 09:57 AM
bkoon's Avatar
bkoon
I am running Rotela oil. But i did find the problem.i Did not know that the injectors run such high pressure. I also found ouy that my truck has a small leak and was low on oil. Many thanks any way to the both of you.
Old May 9, 2009 | 10:52 PM
glasseater's Avatar
glasseater
yup our injectors need oil to fire, if the oil is too low then they won't fire correctly or at all!!! great for if you have a HUGE leak that suddenly shows up... never have to worry about the engine siezing from lack of oil since it'll shut off before it gets to that point
lindb40530
19
Nov 9, 2016 07:05 PM
BIGWORM936
Sep 3, 2015 07:21 PM
steve320
Jun 23, 2013 12:58 PM
Harry Thompson
1997 - 2003 F150
Aug 28, 2009 07:48 AM
MARTYSTOWRIG
General Automotive Discussion
May 24, 2008 06:48 AM
