A.C. intermittantly warm
Old May 10, 2009 | 08:54 PM
dstig1's Avatar
dstig1
PM sent - I can show you the manual pages
Old May 10, 2009 | 09:11 PM
firemediceric's Avatar
firemediceric
Nothing in my PM box...feel free to send it to my screen name at yahoo
Thanks
Old May 11, 2009 | 07:16 PM
firemediceric
Got it done and the AC worked flawlessly today.
Thank you for the insight both as to the problem and how to fix it.
Old May 11, 2009 | 07:26 PM
dstig1's Avatar
dstig1
Happy to help! Glad it worked out for you!
Old May 11, 2009 | 07:51 PM
projectSHO89's Avatar
projectSHO89
See.. Wasn't that hard, now was it!
Old May 11, 2009 | 08:04 PM
lsrx101's Avatar
lsrx101
Everyone said 15 minutes. If it actually took that long, you took a beer break in there somewhere.
Good Job!
Old May 12, 2009 | 10:37 AM
Capt.Schenk's Avatar
Capt.Schenk
I'm having the same problem with my A/C, so I figured I'd post on this thread. After reading y'all's suggestions, I cranked-up my truck, popped the hood, and sure enough, the compressor clutch(?) was not engaging. I tapped it with a screw driver and it engaged, but only for about 20 seconds. I watched for a while and it would engage for 20-30 seconds and disengage for the same amount of time. It went through this cycle about five times and then I closed the hood. It blew very cold while engaged and very hot while disengaged.
Does this problem sound like it has to do with the gap, or another problem?
Old May 21, 2009 | 09:10 PM
rustyoldford's Avatar
rustyoldford
that sounds like low refrigerant to me. About 2 cans in my grand marquis, every spring cures it.
Hoever, the climate control brain is failing now, way to often it decides car is cold, whoosh hot air, out the vents, shut it off and turn on again - works another 10 minutes. Wish it had that much heat in winter!
Old May 21, 2009 | 11:59 PM
lsrx101's Avatar
lsrx101
Actually, Capt.Schenks problem is the clutch gap. His refrigerant "might" be low. but there's absolutely no way to tell until the clutch gap issue is addressed. " It blew very cold while engaged ..." indicates the refrigerant level is probably pretty close.
Your issue, on the other hand, is an obvious large refrigerant leak (just reseal those leaky Spring Lock fittings already, won'tcha )
coupled with a flaky Blend Door Actuator. You'll be in a very small minority if the issue is actually in the EATC Controller (brain box).
Unfortunately, replacing the BDA requires removing the whole instrument panel. It's not "hard", just time consuming. (Assuming your GM ~1990 or newer).
Old May 22, 2009 | 02:02 AM
rustyoldford
blend door actuator , that would be the annoying clicking noise from under the dash, that only goes away if the temp is set within 2 degrees of actual.!!!! Caused by cheap plastic parts that broke.!!! And doesn't quit even when you hit the off button. Naw I think this one is a different problem, I'm just blaming the brain because its to expensive for me to fix, and I need an excuse to replace the car when the big 3 bring my job back from mexico.
Lock spring fittings,?? at least none of the leak dye is showing up at the fittings I see. And 2 cans a year is cheaper then professionally repairing it. Besides 97 merc with a couple small dents, peeling paint is worth about $1500 if you can convince the high school kid the bda is nothing to worry about, with or without air,
Pompanosix
Feb 22, 2019 05:32 PM
bentcipher
Jul 1, 2018 10:20 AM
Mike Isley
1983 - 2012 Ranger & B-Series
Nov 26, 2016 08:33 AM
BTKillerr
Escape & Escape Hybrid
Aug 28, 2015 06:04 PM
Kargh
16
Jun 11, 2010 06:54 AM
