Which Gauge is Better??
Old May 7, 2009 | 12:00 PM
strokersace's Avatar
strokersace
Originally Posted by SuperDoodie
Get a scan guage! Monitors a bunch of stuff and can clear and read codes as well as tell you your injection control pressures.. IIRC, they can be had for $270-ish
Excellent point Greg.
I forgot about that!
Old May 7, 2009 | 12:01 PM
03_PSD's Avatar
03_PSD
Someone got a link for the Scan Gauge?
Old May 7, 2009 | 12:08 PM
CSIPSD's Avatar
CSIPSD
Originally Posted by 03_PSD
No, but they are going to be Dipricol.
As far as your indivdual gauge choice, Fuel pressure will leave you on the side of the road well before a "weak" HPOP...
Fuel pressure should be anyones #4 gauge.
Take another look at Isspro gauges, in your case where you sound like you might add more gauges down the road, the Performax line is right up your alley... You can run up to 17 gauges off the ESP box under the hood. All your sensor wires run to that and only three wires go thru the fire wall to run 17 gauges. You can have senders hooked to the ESP, and swap gauges out as you need them...
Say your pulling a camper to the track, you would run a pyro, fuel pressure, boost and tranny temp....
But once at the track you would not need a tranny temp, pull the tranny temp and install a HPOP gauge... Just that easy!
You can data log thru all your gauges, Peak recall (at the end of the track you want to know what your max boost was... Push a button and all your gauges go to there max reading)
Take a look at the Performax, there doing a 100 rebate for a few more weeks I think too...
Old May 7, 2009 | 12:11 PM
03_PSD's Avatar
03_PSD
That's a great post CSIPSD, thanks for the info.
Old May 7, 2009 | 12:14 PM
jeff7825's Avatar
jeff7825
Well I stand corrected. I just went ahead and got both though, so it didn't matter to me.
Old May 7, 2009 | 12:36 PM
SuperDoodie's Avatar
SuperDoodie
I think there a few places that sell them, but this one comes to mind.
Terminator Engineering
Oh and you can do injector buzz tests and cylinder contribution tests as well..
Old May 7, 2009 | 12:54 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Couldn't have said it better myself. Thanks Joe
These gauges are definitely they best on the market and they match the stock dash perfectly. The $100 rebate is only on for another week though.
Old May 7, 2009 | 12:59 PM
CSIPSD's Avatar
CSIPSD
Here is a pic of mine...
Old May 7, 2009 | 01:12 PM
03_PSD's Avatar
03_PSD
That looks pretty cool Joe!
bismic
Mar 7, 2026 11:32 AM
snaponprofile
50
Mar 12, 2011 09:41 PM
weberr7
May 29, 2007 11:12 AM
Deuce33
Apr 30, 2004 08:10 PM
pancartom
Jun 19, 2003 11:06 PM
