1989 F-350 voltmeter
Old May 7, 2009 | 04:55 PM
bart f-350's Avatar
bart f-350
Hello to all,
I wonder, it might be a silly question, bust does somebody here know where Ford takes the connection (where they get the 12V signal) for the original in dash voltmeter? 1989 F-350 4x4 7.3L IDI diesel.
Or eventually, what is the methode for checking the gage?
any help will be appriciated!, Bart
Old May 7, 2009 | 05:14 PM
Franklin2's Avatar
Franklin2
If I remember correctly it's tapped off the supply that goes to the instrument cluster to power the other guages.
Old May 8, 2009 | 02:14 AM
bart f-350's Avatar
bart f-350
Thanks Dave,
when i have a little more time, i'll look at it.
and i'll let you know if it is the one.
Merci, Bart
Old May 8, 2009 | 08:51 AM
bart f-350's Avatar
bart f-350
Hello Dave,
Today i opened up the instrument cluster, and i noticed after i removed the transparant screen, the little (sub)clusters which are clamped at the instrument cluster chassis.
So i lifted the subcluster with the Volt and Temp. meter out, and took it in my shop.
I checked the functionallity with a preselected current feed, and the meter is fully functional.
Though the thing i discovered, was that the black plastic layer at which the scales are printed was sagged a littlebit, so that the little black cap which rested at the pointer, blocked the movement of the pointer beyound the 9 Volt mark.
After i discovered this, i dicided to cut a little more of that plastic layer, so that the pointer again is able to move freely.
After that, i remounted the instrument cluster, and everything works fine again.
Thanks!
Bart
