clutch linkage
Old May 6, 2009 | 12:04 PM
oldfordcoupe's Avatar
oldfordcoupe
Question clutch linkage
does anybody hav a photo of the clutch bar from the engine to the frame on a 65 stick . the po changed the truck to an auto with a 360 and i want th swap it back to a stick ???
Old May 6, 2009 | 03:52 PM
daveengelson's Avatar
daveengelson
If I have not already done so, welcome to FTE.
Pulled headers yesterday on the 65 with the 302; unfortunately don't have the 65 with the 390 at my current location. Seem to recall they are the same only difference with the 302 the pivot ball bolts directly into the engine block and with the 360 believe the pivot ball is on a bracket that mounts to the bell housing. Posting pic's of the setup with the 302, hope of some help!. Expect will be reassembling tomorrow so let me know if need additional pic's.
Again, welcome to the family of Ford Truck Enthusiast.
http://i300.photobucket.com/albums/n...IMG_0005_3.jpg
http://i300.photobucket.com/albums/n...IMG_0004_1.jpg
http://i300.photobucket.com/albums/n...IMG_0003-2.jpg
http://i300.photobucket.com/albums/n...IMG_0002-6.jpg
Old May 6, 2009 | 07:24 PM
oldfordcoupe
clutch linkage
thanks dave i realy don't know what i need for this setup the only thing i have is the bracket on the frame thanks anyway hope to get started on it next week again thanks
Old May 6, 2009 | 09:51 PM
daveengelson
Posting pic of the clutch assembly. In addition, thought I would add this disclamer currently in the infancy stage of trying to figure out how to manuver around newly acquired 64-72 Ford pickup Master Catalog CD, so take these #'s with a grain of salt. With any luck, NumbersDummy will be monitoring this thread and correct me. That being said, the P/N I came up with for the Z bar, or equalizing bar, is C6TZ-7528A, and for the clutch release bracket assembly C5TZ-7A572, which looks exactly like the bracket in my 65 with the 390ci. Not sure these #'s will be of any help, likely find the parts are obsolete and can't find any supplier that has one. Anyhow,, good luck with project.
http://i300.photobucket.com/albums/n...chAssembly.jpg
Old May 6, 2009 | 11:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
The 1964/72 FORD TRUCK PARTS CATALOG is available on a CD from hipoparts.com for around $22.00 + shipping.
The diagram you want to look at...is in: Illustration Section 75 on page 25.
You could contact obsolete parts vendor GREEN SALES CO. (greensalescompany.com-513-731-3304) in Cincinnati OH and ask them to send you this illustration via email or fax.
There's far more to it than just the Z bar and frame mounted clutch pivots...so you need to see this illustration.
EDIT: Maybe Dave can scan and post this illustration for you, as he has this part catalog. Everything you need is shown.
Old May 7, 2009 | 12:28 AM
daveengelson
Rebuilt clutch assembly and found majority of the parts can be purchased thru Ford parts suppliers. Only mentioned the major components that may difficult to locate like the Z Bar, and equilizing brackets.
LMC Truck Parts - Page 94
Old May 7, 2009 | 06:47 AM
White97's Avatar
White97
Number Dummy helped me find most of my pieces. Mine was never converted to auto, but rather was a mix of homemade parts to make the clutch engage. The bracket going on the block was a tough find, but Bill did find one. Bushings and clips for the z-bar came from NPD. I've also been trying to find a clutch rod boot - out of stock everywhere. NPD sources from DC, DC is out. Going to try Macs. The bushings on the clutch rod I made from nylon spacers I got at home depot.
Getting the clutch movement right was expensive and a pain, and mine was already a standard. You may want to consider an aftermarket hydraulic setup. Good luck!
Old May 7, 2009 | 07:36 AM
NumberDummy
The bracket going on the block was a tough find, but Bill did find one Just found two C5TZ7A572A more at obsolete parts vendors. This fits 1965, some 1966's.
Bushings and clips for the z-bar came from NPD Still available from Ford.
I've also been trying to find a clutch rod boot - out of stock everywhere Not quite.
The bushings on the clutch rod I made from nylon spacers I got at home depot. Here's 136 of them, there more still out there.
1) D2TZ7A533A .. Clutch Rod Boot / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
TEHRANI MOTOR CO. in Valentine NE has ONE.
YADKIN VALLEY MOTOR CO. in North Wilkesboro NC has ONE.
NO other Ford Dealer or obsolete parts vendor has any.
2) COAZ7526B .. Clutch Rod Bushings / Obsoleted by Ford just recently.
PIEDMONT FORD TRUCK in Greensboro NC has 54 = 336-668-2401,
PARTS INTERNATIONAL in Farmers Branch TX has 50 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 22 = 800-543-4959.
JST AUTOMOTIVE in Lebanon TN has 10 - 615-443-3086.
The following parts are STILL available from Ford:
2) CIAA7543A .. Z Bar Bushings
2) 358979S .. Z Bar Felt Washers
2) 97474S .. Z Bar Snap Rings
4) B7AZ2471B .. Clutch & Brake Pedal Shaft Bushings
2) B7A2457A .. Clutch & Brake Pedal Pads
Old May 7, 2009 | 11:05 AM
daveengelson
Has anyone mentioned the pedal assembly. May want to rethink the automatic tranny, not knowledgeable with the vintage automatic's, perhaps swapping or an upgrade would be a solution. Salvaged a C6 yrs. ago that has been collection dust waiting until time permits to install in the 65 with the 3sp w/ o.d. Anyhow, got the urge to chime in and add my .
Old May 7, 2009 | 06:50 PM
oldfordcoupe
clutch linkage
ain't this site wonderfull!!! i have to go to nashburg this weekend but will be back on the truck next week. i have to replace the left front whl. cyl. before i can get the brakes to work. and will have to order the part because nobody has one in stock but nexk week is coming later you-all
Old May 8, 2009 | 01:15 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
oldfordcoupe
I think that if you are buying all the parts to swap your truck back to ( Manual ), I think
that you will want to get the part # and location and price of the ( Big Long Spring )
that hooks on the clutch arm and goes forward to the crossmember ! You may also
will probably need the ( small short spring ) it hooks to the top of the Pedal and hooks
to the same bracket the Pedal bolts to ! I also don't remember seeing the ( Rod from Pedal to Z-bar ) you will need these parts also,
if the PO didn't leave them on your Truck ? I have traded for lots of these old trucks that had been Swapped to ( AUTO ) ,and find they had left
the Pedal and just pulled the carpet over it .....
Wally Womack
Old May 8, 2009 | 02:50 AM
NumberDummy
C5TZ7521B .. Clutch Rod-Clutch Pedal Bellcrank to Z Bar / Obsolete
C5TZ7A600B .. Clutch Return Spring-Clutch Pedal to Dash Bracket / Obsolete
C7TZ7523F .. Clutch Fork Return Spring / Obsolete
DOTZ7521A .. Clutch Adjustment Rod / Obsolete
C5TZ7528A .. Equalizer (Z) Bar / Obsolete
C5TZ7507A .. Clutch Pivot-Frame Side / Obsolete
C5TZ7A572B .. Clutch Pivot-Engine Side / Obsolete
C3AZ7515C .. Clutch Fork / Obsolete
C5TZ7513A .. Clutch Fork Rubber Dust Shield / Obsolete
C6AZ7562A .. Clutch Fork Anti-Rattle Spring / Obsolete
B9AZ7522A .. Clutch Release Lever Trunnion / Obsolete
C5TZ7519A .. Clutch Pedal / Obsolete
C5AZ6375K .. 352/360 Flywheel / Obsolete
Some of these parts will be impossible to find new. Some of these parts can be found new, but will not be cheap!
IMO, the OP should find a 1965/66 F100/250 352 2WD and remove all the parts...then replace the stuff that is worn.
I will search for these parts...after the OP decides what he's going to do.
I would suggest the OP contact FTE member camperspecial65, as he can prolly find all this stuff used.
Old May 11, 2009 | 11:47 AM
oldfordcoupe
thanks nd i just got bake home and i will see what i can come up with this week thanks again
Old May 23, 2009 | 11:55 AM
tkodrummer's Avatar
tkodrummer
oldfordcoupe, I just pulled a 352-4speed from my 66 100 and installed a 429-auto. Just yesterday I pulled the pedal assm. out to lose the clutch pedal. I`ve got a 66 250 that came with 352-auto for parts. I sold the motor but still have everything else.
Dan
Old May 23, 2009 | 01:37 PM
oldfordcoupe
thanks 'tkodrummer' i'll try to get back with you after this weekend
