Differences in 7.3 Engine from 95-00
These engines look to be interchangeable, are they? I believe the injectors, turbo, intake, and things like that are different, and would have to be swapped out. I have a lead on a very low mile 96 7.3 engine, and my 00' has a cracked block , so I was wondering if i could swap it. That would also be a perfect time for some upgrades, definitely bellowed up-pipes.
Thanks for the help.
Joe and Chase are right about the mechanical fuel pump on the 96, but there's no holes to plug that I'm aware of. Well, now that I'm thinking of it, I think there's a soft plug (like a press in plug) that might need to be installed. Here's a pic of the SD motor and I bet that's what the plug is for in the valley.
As they've said, the intake pluemns, turbo, pedestal, up-pipes, hpop, fuel system, injectors all need to be swapped. Also the engine wiring harness will need to be changed to the SD. The timing/water pump cover is also different between the 2. You'll need to swap that as well. The hpop resevior etc. will go with it. Last but not least, the a/c and alternator brackets need to be swapped cause they are reversed on the 96. Same bolt holes so it's easy.
Hope that helps!!
Hope that helps!!
Excellent info on the cam Chase. I was wondering what made the mech pump work!!
Taking a look at the "coffee table" books should help in seeing the differences between the motors: Diesel Technician Society
