having a problem
Old May 6, 2009 | 01:16 AM
NubVan's Avatar
NubVan
having a problem
I have a 93 E350 and having some issues with it, pardon me for asking this as I am sure it has been asked before, I did search but I am on a 1x connection and it keeps booting me off. ok here goes
my van has 148k on it, always a solid runner before this issue. it started idling high and also has a hard starting problem. There is no check engine light on and I have not run the codes yet, If I unplug the AIS the idle does drop to around 750-800 and will die out if I do not keep the foot on the gas while at a stop sign. I have tried different AIS and TPS, off of a known good running 5.0L (mine is a 351) I have sorted through vacuum lines and did not find any leaks. I did replace the fuel filter at 147k but that was long before the problem started, (the old filter was very hard to blow through. The hard starting issue is more like a NO starting issue unless I use a bit of starting fluid to get it to pop over, with that known it almost makes me think that it is a fuel problem, I do not have a fuel pressure tester but that is my next step after this post. Sometimes it will start up like nothing is wrong and the idle will climb from there, wich makes me think that it might be a temp senor fail that is telling the computer to kick the idle up. the dash temp gauge does seem to be working good. I am not sure wich sensor it is that feeds the computer for the high idle circuit. I am not sure on what other imput you guys might need. The cat is hollow, otherwise all stock. it has recent cap/wires/rotor and air filter. Oh It did have a problem shifting into overdrive the last time I drove it, I plan to tackle that next (fluid/filter,ect..) That was when it was about -25 outside.
any advice is appreciated, thanks in advance -Dave
Old May 6, 2009 | 09:22 AM
Club Wagon's Avatar
Club Wagon
By all means "run the codes" OBD is no joke, there may be a code thrown even w/o the CEL.
Old May 11, 2009 | 06:09 PM
NubVan's Avatar
NubVan
YouTube - VIDEO0026
could someone try to count these for me? I keep getting different numbers each time lol. this is a koer test
Old May 12, 2009 | 01:29 AM
NubVan's Avatar
NubVan
well I changed the ect sensor hoping that it would fix the problem, still idling high. I cleared the codes by disconnecting the battery for 10 mins and now to fix a brake issue so I can drive it 10 miles before checking the codes again. how log are codes stored in the memory?
Old May 14, 2009 | 07:45 AM
2000Ford2000's Avatar
2000Ford2000
Never had a 93 but does it have an IAC?
Don't think it could affect the starting though, but most definitely the idling. I've had them fail both on an 89 5.0L and an 00 5.4L.
Old May 17, 2009 | 06:56 PM
NubVan's Avatar
NubVan
yes IAC is what I was referring to by "AIS" I grew up working on 80's mopars and that is what controls the idle on them
I just used a code scanner with a beep output and this is what I got from it.
either, this
or if it is a 3 digit code,
121
121
111
111
I am guessing it's a 3 digit, can anyone confirm this? will a faulty tps cause a hard/no start? this is still a koeo test, I am going to clear the codes again and run them, I did not run it 10 miles like suggested by the trouble code site that I used..
