Alt/voltage regulator ?
Old May 5, 2009 | 08:38 PM
Dads79's Avatar
Dads79
My truck battery is not recharging. The volt meter gauge drops slowly after I get it running. Headlights get dim. Battery is new,but will get it checked.There is a magnetic pull on the back of the alt (maybe that's a old tale). If I replace the alternator,which one should I get 50,60,70,or 100 amps. Truck is 79 F-150 4x4 400 V-8 ,C-6 came with ps,pb,a/c,cruise.Could it be the voltage regulator ? Should the voltage regulator be matching to the alt ? Is there an after market upgrade that I could do.I am in the local VFD,so I do plan on adding lights and sirens at some point.Just trying to do this once. Thanks for your help.
Old May 5, 2009 | 08:56 PM
trailblazer28333's Avatar
trailblazer28333
its possible that the voltage regulator could be bad... although in the different dentsides i've owned over the years have never seen one go bad... i would pull the alt and have it checked. not quite sure on the amperage that lights and sirens pull but i would think a 70 amp alt should be effiecent.... dont know what u mean by voltage reg matching to the alt.... but i dont believe the voltage reg measures amps just volts.
Old May 5, 2009 | 09:16 PM
jacfordf-250's Avatar
jacfordf-250
go with the 100amp you can never have to much power now a days
Old May 5, 2009 | 11:14 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
3G swap is your best bet... do a search it's well worth it.
Josh
