hey all having problems with the wipers. If i leave the pass side wiper arm off it works fine but when i put the passenger arm on, it moves too far to the drivers side and gets stuck? maybe linkage needs to be tightened? i have no idea. Maybe i'm putting the arms on wrong? thanks. o and by the way its 1 speed motor and 66 250. thanks guys.
alright thanks that's under the dash right? pita to get out lol? and while i got the thread when i put the arms on they go all the way to the left if I'm correct? and the blades are horizontal on the windshield?
If you want to check without removing motor. Hold thumb at end of articulation of wipers. If wiper will bump against your thumb and return there is a good chance it is wear in the gear. Have you lubricated the articulating joints?
no i havent lubricated it its all new to me they worked and now they don't lol ill try that thumb thing. I'm driving it now with just drivers side on and its alright i just want to have it good for safety reasons. thanks man.
Say BWForge,
What do you lube the linkage with? Never-seize? teflon spray?
I suspect you have to remove the vented cowl section to get to the linkage, correct?
