Brake problem, Vacuum leak?
Old May 4, 2009 | 07:29 PM
gthbryce's Avatar
gthbryce
Over the past month I have noticed my brake pedal at red lights going farther and farther to the floor the longer I sit there. I usually have to push really hard as to prevent my 460 bohemeth from rolling over vehicles in front of me. There are no brake leaks, I have never added brake fluid since i got the truck from my brother which has been 5k ago and it's still at the same level. I have noticed this however:
Now if in fact this brake booster line or plug seal thingy is the culprit, can the plastic plug come completely out?
Old May 4, 2009 | 07:36 PM
dustybumpers's Avatar
dustybumpers
that just pulls out, but more likely your master cyl is worn. when it leaks down like that, pump it a couple of times, and see if the pedel pressure returns. re built master cyls are cheep, under $40. just bench bleed the new one, install, and bleed the brakes, you will have good brakes again
Old May 4, 2009 | 07:37 PM
subford's Avatar
subford
They do not normally come out on there own.
But it does sound like you have a bad master cylinder.
Old May 4, 2009 | 07:55 PM
gthbryce's Avatar
gthbryce
The master cylinder got replaced already...So it's not sounding like the booster?
Old May 4, 2009 | 08:06 PM
dustybumpers
no, try bleeding the brakes again, you still have air trapped in the system. booster either works or not. you would hear a hissing sound from under the dash if it was bad, but it would not act like that
Old May 4, 2009 | 08:08 PM
gthbryce's Avatar
gthbryce
The master cylinder got replaced last summer and it just happened recently, could it still be air in the system?
Old May 4, 2009 | 09:22 PM
gthbryce's Avatar
gthbryce
When the truck is off If i push really hard on the brake pedal and hold it my foot slowly goes to the floor. When the truck is running and I push the pedal it gets hard sometimes but still eventualy goes to the floor.
Old May 5, 2009 | 04:59 AM
dustybumpers
air in the system, or bad master cyl. I'm done now.
Old May 5, 2009 | 06:40 AM
jr32560's Avatar
jr32560
yeah I agree with the other posts air in lines or a bad master cylinder
Old May 5, 2009 | 06:44 AM
Lazy K's Avatar
Lazy K
I agree with all these guys. It is NOT the booster. It could, however, be a faulty RABS solenoid module.
It is on the inside of the left frame rail about level with the drivers feet.
When you replaced the master cylinder did you bleed it?
If the problem is not air in the system then it could well be a faulty RABS module.
There is an easy way to check it. There is a large hex bung on the front end of it. Unscrew this bung (under spring pressure all the way) and remove the spring. No fluid will come out. Replace the bung without the spring, give the pedal a few pumps to fill the chamber and then try the brakes. If they are now good then the RABS module is bad, if no change then replace the spring and look elsewhere.
Old May 5, 2009 | 04:20 PM
gthbryce's Avatar
gthbryce
Well I don't know if this has anything to do with it but since I got the truck the rear abs light has been lit up...
Old May 17, 2009 | 11:26 PM
gthbryce's Avatar
gthbryce
5-17 I bled the brake lines but..
Is it normal to have any hissing at all come from the brake booster when pressure is applied on the brake pedal?
Old May 18, 2009 | 04:53 AM
Lazy K's Avatar
Lazy K
No it`s not but that is not the cause of a sinking brake pedal.
PapaMatt
35
Aug 27, 2014 08:11 PM
HydroTek
Oct 10, 2012 05:05 PM
ron reece
Modular V8 (4.6L, 5.4L)
Oct 7, 2007 11:13 PM
ron reece
1997 - 2003 F150
Oct 7, 2007 06:07 PM
jux
Oct 16, 2005 03:41 AM
