newer 300 timing marks
Old May 4, 2009 | 06:12 PM
nevrenufhp's Avatar
nevrenufhp
I got a harmonic balancer(3rd groove for future power steering) from an 83 E100, and I'm pretty sure it has different timing marks. Did they use a pointer on the pass side? I set the timing by vac gauge, and a lot of test & tune. The old marks on my(who know how old) 300 say it's 28* initial. If I go to the pass side, it reads in the teens. Just wondering what it's at so I dont get too much total advance.
Old May 4, 2009 | 06:35 PM
Harte3's Avatar
Harte3
As long as you are not getting ping under load you won't have too much.
Old May 4, 2009 | 06:57 PM
nevrenufhp's Avatar
nevrenufhp
Too much or not enuf is just a slight worry. It used to ping under load, so I tightened up the 2 dizzy springs(2 light ones used). Runs velvetty smoooth and power is good.
Old May 4, 2009 | 07:06 PM
dustybumpers's Avatar
dustybumpers
find top dead center, and paint a mark where your old pointer is. then time as normal
Old May 4, 2009 | 07:15 PM
nevrenufhp's Avatar
nevrenufhp
I think that just may have to be the way to do it, Thanks.
Old May 12, 2009 | 06:57 PM
nevrenufhp's Avatar
nevrenufhp
I did it with a new paint mark, and it was only a few degrees off. It was then that I realized the Summit ignition box is likely the culprit. I'm thinking that's when the spark event starts(runs milti sparks for 20* of rotation), so I just gotta tune by ear as I've been doing. All is happy, and mpg is up a little now that its dialed in a little better.
Old May 12, 2009 | 07:06 PM
Harte3's Avatar
Harte3
Easier starting too? When I installed a Mallory HyFire 6a, my engine fired like a rocket even in butt-cold weather.
The Summit Street & Strip is a pretty good buy for an after market box.
Old May 12, 2009 | 08:14 PM
nevrenufhp's Avatar
nevrenufhp
I was going from points, so I needed to get some sort of box, and the Summit was essentially a Mallory(according to the spex). It fires up super easy hot or cold, dont even need choke above 50*. I have almost the same setup as you, except the cam exhaust, & ported head.
1968f100
35
Jul 16, 2025 08:47 PM
maverick600
Sep 16, 2013 06:28 PM
nolan62
Dec 9, 2010 08:15 AM
F250DUDE66
Sep 4, 2008 08:22 PM
chrono4
Feb 6, 2008 09:35 PM
