What mods do I need...
Old May 4, 2009 | 03:37 PM
varmintboy54's Avatar
varmintboy54
Question What mods do I need...
My truck is a bone stock 1997 F-250 4X4 auto with 3:55 gears and 140000 miles.
I bought it to tow a 6000 lb boat and trailer. I want to get it setup for towing, right now it dose ok but it needs more power and better shift points, it won't kick down past 40 mph and this is with OD off. I don't want to go crazy with mods but I was thinking about doing the chip thing. What mods should I do before I install a chip?
Mike
Old May 4, 2009 | 03:47 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Without going crazy or spending a whole lot of money.....
6637 intake, 4" exhaust w/new down pipe, shim fpr, 14.7 or just jump to a TW chip, I hear good things about the cure but have no experience.
Old May 4, 2009 | 05:01 PM
IDMooseMan's Avatar
IDMooseMan
Sounds like a good start. Don't forget to add gauges so can monitor what's going on.
Since you want to tow things, EGT and tranny temp gauges are a good idea and you might as well throw in a boost gauge, too.
Old May 4, 2009 | 05:48 PM
varmintboy54
Ok Great
Tell me what you mean, shim FPR...Fuel Pressure Regulator?
Whats 14.7,
Any suggestions on pod and what gauge's to get?
Old May 4, 2009 | 06:51 PM
79_250RangerLariat
Forgot the most important part... the gauges! You'll definately want those. I didn't use a pod, I made a alum box that fits on the floor between the shifter and center console. I don't like the added blind spot. As far as gauges I'm running autometers, they are pretty good.
Yes, the shimming the FPR is the fuel pressure regulator. A BB is the perfect size, just take before and after fuel pressure readings to make sure you don't go too high. I'm running 75 psi and hear it's about borderline. The 14.7 mod is a resistor put inline with the ICP, tells PCM it needs more HPO to build more fuel pressure. I'll try to find the link, but if you use the search forum function you'll find lots of mods and good directions. Coon's way makes it easy to swap resistors, some trucks like different sizes than others.
Old May 4, 2009 | 07:17 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Yup, what they said! Definitely guages. The FPR shim easy and cheap. Also, the EBPV brake is a really cheap and helpful mod for pulling. Mind you, with an auto, you'l have to do the TC lockup thing too. Myself, I'd go with the chip, but that's up to you. Do the intake, exhaust, and guages first. Oh yeah, cat delete is a really good one too. (can be real cheap if done right)
Old May 4, 2009 | 08:05 PM
73cntry's Avatar
73cntry
What exhaust manufacturer do you recommend? Looking at going with a 3in or 4in exhaust system. Already have no Kitty but stock down pipe. I've heard MBRP is a good system.
Old May 4, 2009 | 08:15 PM
oldbird1965's Avatar
oldbird1965
varmintboy54, I know that's a lot to swallow. If its only a 6k boat, don't worry about everything at once. If you only do one thing, do the 6637, downpipe and straight pipe. That alone makes a world of difference. Then take it one mod at a time, all good suggestions above! I will say one thing though, the heavier the load the more you need a EGT gauge. When I tackle the mountains with my 15k 5er and get into a real hard pull the guage I watch the most is the EGT gauge. The higher it goes up the less I push on the old throttle.
Old May 4, 2009 | 09:46 PM
varmintboy54
Thanks for the info, this sounds like good info for a good start. I do want to run a chip being it ties everything together and makes it all run smooth...
I like the Idea about the 6637 air filter mod, cheep and effective. I have heard the stock down pipe is very restrictive and needs to be changed. Will removing the cat cause any problems going thru emissions? Going to do some searches on all of the suggestions you guys made. Thanks for all the info. Now I just need to find some how to's here that show hows it done.
Mike
Old May 4, 2009 | 09:58 PM
oldbird1965
Mike
Do you live in a state that does emission testing?
Old May 4, 2009 | 10:23 PM
varmintboy54
Washington State and I thing they do diesels now, but I will check.
Mike
Old May 5, 2009 | 02:02 PM
varmintboy54
Just ordered the 4"Diamond Eye exhaust off of ebay and I am going to the auto store for a filter. I read people are using a 45 degree PVC elbow from Home Depot but where can I get a metal one ?
Mike
Old May 5, 2009 | 02:14 PM
superduty4x4's Avatar
superduty4x4
Mike
Good luck with the Diamond Eye system... I hope yours fits better than mine!
For the 45 deg. elbow try Schucks or Napa, or a big rig truck store.
Where in WA state are you? Only parts of the state require emissions testing.
Old May 5, 2009 | 02:35 PM
cowmilker08's Avatar
cowmilker08
Mike
riffraff diesel performance has a good kit.
Old May 5, 2009 | 02:39 PM
superduty4x4
Check with Clay, but I don't think he's offering a kit with the 45 degree bent pipe.
