NAPA part #
Old May 4, 2009 | 02:36 PM
mjtpolice76's Avatar
mjtpolice76
NAPA part #
looking for the napa part# forl the upper radiator hose that moves it around the serp belt? When u change the hose will it cause an air lock that will have to be bled out or will the system work it out by itself.
Old May 4, 2009 | 03:00 PM
Izzy351's Avatar
Izzy351
Don't know the part number, but I seriously doubt any air would get stuck. I know that when doing a flush SOME air works its way to the de-gas bottle, so keep some distilled water with you after you open the system...
Old May 4, 2009 | 03:58 PM
dvfd12's Avatar
dvfd12
It should be #9066
Old May 4, 2009 | 04:05 PM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by dvfd12
It should be #9066
yup, that's the one. when you change it out, just drain about 2/3rds of the radiator fluid into a clean bucket, swap the hose and refill. Very easy.
Old May 4, 2009 | 04:25 PM
mjtpolice76
k thank you
Old May 4, 2009 | 05:42 PM
Tim J's Avatar
Tim J
When I did a coolant flush.....I replaced the hoses. No air lock problem. Just fill and run. Top off when cools down again.
