97 F359, factory trailer wiring harness. I bought he pigtail to connect the brake controller and brakes work, as do brake and running lights, right and left flasher. sofar so good.
This leaves 2 circuits on the 7 pole connector......Auxillary and trailer power.
1 - Trailer power (battery charge, top right connector on the truck plug) has a 30 AMP maxi fuse oin the power distribution box. The fuse is good and has power. But I get nothing at the plug. Its the orange wire on the factory harness. Any idea where I should start?
2 - Auxilary connector. Again its factory prewired and connected to the trailer plug. Since it is an optional circuit I assume that Ford did not connect it to an existing circuit. Or did they? Anyone know where this wire terminates?
1 Is the truck running when you test for the trailer power, the truck has a relay and doesn't give power to that circuit if the truck is not running.
2 - the auxilary circuit should be for the reverse lights if I remember right
2 - So you think that when the truck reverse lights are on, the trailer backup lights should be energized?
Yes.
Try disconnecting the plug at the harness under the bed, and test there. Maybe that connection/plug is bad. Otherwise the only other plug is up near the firewall if I recall correctly, try there. If nothing still, then ???
x2 .. both circuits require separate relays. Are they there ?
When I bought my rig the trailer plug had a couple dead circuits. I back traced the harness from the plug forward and found that the 12V charge wire and backup light wire were not connected to the plug. It did not look like a "custom" repair, looked pretty factory to me the way it was secured. Not sure why they weren't connected, but once fixed everything works as it should.
