Forgot Login ID
Old May 4, 2009 | 01:15 PM
metalshaper's Avatar
metalshaper
Forgot Login ID
I forgot my login ID and had to register under a different name to get back on here,so I am not new to this forum but have not been here for along time.I need a new Intake and brake rotors,I also have a bad exhaust drone and need to do something about that.Any help for these problems?
Old May 4, 2009 | 01:25 PM
JockD's Avatar
JockD
On your exhaust drone - what system do you have? Stock, muffler delete, etc.?
Old May 4, 2009 | 01:26 PM
03_PSD's Avatar
03_PSD
Cheap intake = 6637
Do you have a straight exhaust?
Old May 4, 2009 | 01:40 PM
metalshaper
I have the 4" mbrp exhaust and the 6637 Intake, I have a bad drone at 50 mph to 65 mph IT goes away at 70 mph.I think I need a resonator of some kind.Also have the DP -tuner with 3 tunes.40,60 and 80 economy.
Old May 4, 2009 | 01:43 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Old May 4, 2009 | 01:49 PM
03_PSD's Avatar
03_PSD
does your exhaust have a muffler?
Old May 4, 2009 | 01:57 PM
metalshaper
yes I Have a muffler. The dimples inside the muffler are pointed or open toward the back.
Old May 4, 2009 | 02:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Make sure your exhaust pipe is not hitting the trans cross member bolts. That is a common place for the pipe to hit and make drone. The drone I had was the downpipe hitting the firewall.
Old May 4, 2009 | 02:14 PM
metalshaper
I put this on and I don't think it is touching anywhere.It has had a bad drone from day 1,its been on a little over a year.
Old May 4, 2009 | 02:30 PM
pbr man's Avatar
pbr man
I had a drone after I straight piped mine. I installed an Aeroturbine when I put a 4'' exhaust on and I have no drone at all. I picked up the Aeroturbine fairly cheap as a guy had one new in box that he never got around to install (his loss,my gain). I was skeptical at first about the claims from the company but after running it for about 9 months I am really happy with it.
I would have never bought one at full price at first, but after having it one rig,I would spend the money if I had to do another.
Old May 4, 2009 | 02:41 PM
miller_feed
Is the drone worst while turning one way or another?
Old May 4, 2009 | 02:57 PM
metalshaper
No, just at speed,50mph to 65 mph.
Old May 4, 2009 | 03:04 PM
miller_feed
I don't know, maybe turn the muffler around?
Old May 4, 2009 | 03:24 PM
Izzy351's Avatar
Izzy351
I don't think it's the muffler -- I get SOME drone from the intake. You might try building a box around the 6637 or try a commercial option with a box around it, like the AIS...
Old May 4, 2009 | 04:17 PM
metalshaper
I have put a box around it and used foilback insulation over it and it did help,I am thinking I need a intake as well as some type of resonator for the exhaust as well.I have not researched any intakes,would an AIS be a good one? Riffraff is sending me some info on something as well.
