stock wheel ?
Old May 4, 2009 | 01:14 PM
emtzach's Avatar
emtzach
Arrow stock wheel ?
how wide tall can i go with stock 17 on my 05 150 i want mudders i will be leveling this weekend . p.s i dont mind triming if need be
Old May 4, 2009 | 04:10 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
12.5" wide....will put your tire about 1/4" from rubbing the upper control arm
4x2: 34" tall with 2.5" leveling kit
4x4: 35" tall with 2.5" leveling kit
Might have slight rubbage on lock-lock...but a bit of fender well trimming usually seems to fix that
Old May 4, 2009 | 04:34 PM
emtzach's Avatar
emtzach
will a12.5 fit on a stock wheel ive never had to try but i have to be super thrifty if poss baby on the way
Old May 4, 2009 | 04:54 PM
jerichow83's Avatar
jerichow83
i went 33's x 11.5 looks good, which converts to 285/70/17
Old May 4, 2009 | 08:42 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes. I have test fit them myself, and they fit just fine. Avoid the super aggressive side lug tires though...like Baja Claws. They might rub the upper control arm
Look up BrianjWilson. He has an identical version of my truck with 3512.5/18 KM2 mudders. He and I swapped a few PM's and he says he has 0 issues with them after 8,000 miles.
Old May 5, 2009 | 10:31 AM
Grrrowler's Avatar
Grrrowler
I went with that same size in the BFG KM2s. I've no problems. I would have liked the look of a wider tire, but I couldn't afford the extra $50/tire to go 1/2" wider. Plus with the aggressive side tread I've only got about 1/4" between the tire and the control arm as it is, so it would have been close.
Old May 5, 2009 | 12:06 PM
emtzach's Avatar
emtzach
thanks for the help p.s does anyone have suggestions on where to buy online cheep ive been looking but not much luck on under 200 a piece
Old May 5, 2009 | 12:23 PM
Grrrowler's Avatar
Grrrowler
Tirerack has some good prices, but I found even better prices on Discount Tire Direct. My local Discount Tire store matched the online price.
A guy on another Ford forum got a good deal on some Mickey Thompsons on a Yahoo store site. He said he took the quote to 4Wheel Parts and they matched the price.
Old May 5, 2009 | 08:38 PM
jerichow83's Avatar
jerichow83
go to sam's club online and check them out they have TA KO, KM2 , GY MTR, DUNLOP MT FOR CHEAP COMPARE TO EVERYONE ELSE
