ford newbe needs help please
Old May 4, 2009 | 07:57 AM
Barret's Avatar
Barret
Hello everyone. I've been lurking around here for a while trying to learn as much as i can seeing as I just bought my first ford. Its a 97 f350 PSD auto, drw and about 320 000 kms on the clock ( about 200 000 miles). Anyway it had been working fine last time it was running but I went to move it today and nothing, Wouldn't even crank over. WTS light didn't come on and the was a clicking noise comming from the under hood fuse box when the key was in the on postion. I plugged in my scanner but it wasn't throwing any codes. Anyone have this problem before that could lead me in the right direction before I start doing this . Thanks
Old May 4, 2009 | 09:39 AM
rideracelivemx7's Avatar
rideracelivemx7
well i had the same thing happen when iwas testing my batteries lol it wouldnt even light anythign up on the driver side battery alone, it would just click, check your grounds, altenator to the starter and in between
Old May 4, 2009 | 11:03 AM
IDMooseMan's Avatar
IDMooseMan
Welcome to
I agree. Could be dead batteries or loose cables. Make sure the battery fluid is at the proper level, both batteries have a good charge and the cables are clean and tight.
Old May 4, 2009 | 09:27 PM
oldbird1965's Avatar
oldbird1965
x2 plus check to see if you left any lights on. Or a draw on the batteries somehow. Sounds like its complety dead, well almost except for the click.
