Starters are the same but the AOD uses a unique flexplate(automatics don't use flywheels) so whatever you do don't bolt that c6 flexplate in there or the AOD will instantly die.
I've been trying to get a lot of my stuff from central Maine to the philly area, and everything is a fortune to ship. They want from 450-600 to haul my turbo ranger project 650 miles. Mostly because it don't run. The cheaper places expect things to be turn key, drive on.
I had been saving the 351/aod combo for a 77 shortbed truck, but again, 600$ to ship it and all my parts to pa. I can haul it myself but then I have no place to put a trailer.
Gauges and trim are missing.
There is no notch in trans pan for modulator so its not a c6.
From memory I was pretty sure the pan wasn't huge like the e4od in my 90 truck.
Ill try to remember to go look next holiday I'm up there... If there isn't a lot of snow still.
Yes a C6 flexplate will bolt in between a 351 and an AOD but it's still not compatible, it has more offset than the AOD flexplate and pushes the TC back into the trans oil pump which grinds parts and sends metal shaving throughout the trans.. rendering it useless very quickly. I have installed a 351 into an AOD truck if that means anything to you.
