Courier wheel bearings
Old May 3, 2009 | 04:39 PM
4jexep4's Avatar
4jexep4
I just bought a trailer that has been made out of a 73-75 Courier truck body. The reason I think it is a 73-75 is that the wheel lugs on the left side are left hand thread, I think they quite this practice in 76. I tore the axle apart to put new bearings and seals in. I believe the axle is a 9 inch 10 bolt. Can anyone verify that this is the stock axle that came with these trucks? The problem I'm having is that the wheel bearings will not budge. There was very little grease in the bearings when I tore into them, some rust and blue spots too. Are these bearing meant to be pressed on and off? Or should they simply come off with a little prying? Any info or past experiences would be helpful. Thanks.
