C6 leaking
C6 leaking
Greetings all,
I just replace the tranny filter & gasket on my 78 F150 (C6) last week. This morning I noticed a puddle of tranny fluid on the floor. It's not the pan that's leaking, it's the nylon-looking thingy in front of the linkage lever that goes into the tranny. Is this the kick-down lever? I don't have a kick-down linkage from the carb, but it looks like it used to.
Is there a seal or something I can get to stop this leak? Can I do it without removing the pan?
Any help would be greatly appreciated!
Thanks.
K.
Thanks.
K.
C6 leaking
Man, I know this doesn't help you out to much. But I have the same problem! I got my mechanic to do a filter and gasket change on my C6 and few days later I checked under the truck and there was a nice downhill leak on the pavement. I checked it out and it is leaking out of the selector that goes into the tanny. I was kind of:-( , I do really hope that someone does reply to your question, b/c im waiting for an anwser 2.
weaver79
'79 f150 Ranger Supercab w/351M mildly modified
weaver79
C6 leaking
I've seen this happen a few times when the tranny is overfilled with fluid. Check the tranny fluid level normally, and if the stick shows a very high full level then that's probably what it is. You can drain some out with a clean axle filler pump and a lot pickup tube. A standard filter/fluid change doesn't effect the linkage at all.
Hope this helps. Polkat
C6 leaking
>you need to replace the nut
Is that because it's a lock nut that doesn't lock anymore?
>and readust the band (120 in lbs
>or 10ft lbs off 1 1/2 turns screw on new nut hold screw from
>turning)
What do you mean by "10ft lbs off 1 1/2 turns" ? I don't understand. Could be it's just monday and I'm not awake yet.
Thanks!
Kevin K.
>turning)
Thanks!
Kevin K.
C6 leaking
I'm going through all this right now. I'm rebuilding my C6 and am about done with assembly. The nut on the band adjusting screw has a rubber seal on the back of it. With time, this will start to leak. When installing a new nut, you have to re-adjust the band. To do this, start the new nut on the screw, adjust the screw to 120 in/lbs (or 10 ft/lbs) Then, back the screw off EXACTLY 1 1/2 turns. Hold the screw from turning and tighten the lock nut down. You will need a special socket to adjust the band. Either a 5/16" square socket, or what I found at Sears. It's a 3/8" drive 8 point socket 5/16" in size. It fits the adjusting screw perfectly.
Fordzilla80
09-30-2012 12:47 PM
Pathogen98
08-14-2011 03:04 PM
thekingofcows
03-01-2011 04:08 AM
Mav06
16
02-12-2007 01:09 AM
ctvanover
04-22-2004 04:12 PM
