The kick down linkage runs down the DS of the engine/transmission. You will need to find the kick down rod from a truck with the same engine and tranny that you have. If the intake manifold has been changed from stock, you may also need a kick down rod extender or bend the rod to get the proper length. You will need two E-clips to attach the rod to your carb and tranny. Summit has the push rod adapters if you need them.
what exactly does the kickdown linkage do?? (im fixing to pull a 4spd and swap a c6.
When you are cruisin' down the highway, and want to pass someone, pressing down on the gas activates the kickdown rod and downshifts (kicksdown) the transmission to a lower gear. When you return to normal speed the trans upshifts by itself.
Where would i be able to obtain a kick down rod? Also would This carb fit a 1973 ford 360. And i was think about converting my distributor from points to electronic.
Your favorite Pick-N-Pull for the rod, get the "E" clips.
Ignition conversion, your choice, I prefer induction vs CD
for the longer spark duration time. Stay away from units that
require a ballast resistor or resistor wire.No name as i'm partial
to one brand after other brand failures, sorry can't post to avoid
product bias on my opinions.
when you say ignition conversion and talk about balast resistor or resistor wires, where exactly are these and are they for auto transmissions or for swaping motors??
If I am not mistaken ballast resistor and resistor wires were used for points style distributors and have nothing to do with automatic transmissions and engine swaps. Ballast resistor / resistor wires were used to reduce the current through the points, so that they did not burn up prematurely. I believe all of the newer electronic ignitions / distributors use the full 12V.
Not all points to electronic conversion units run the full 12 volts, others run
full 12 volts.
In the second case you need to supply a 12 volt feed and not use the factory feed as it has a resistor built in, that would be in the factory wiring harness.
With the electronic units that require ballast or resistor wire all your gaining is the elimination of points, resistor or ballast still limits you coil current.
Current is heat so why limit limit yourself with a resitor or ballast required unit?
Get one that operates on full 12 volts for a higher secondary current at the plug, buy good once. Inductive ignition systems have a longer spark duration which is what is needed on a street motor be it stock or warmed over, JMO.
I don't want to get hammered because of my opinion about other brands in inductive vs capacitor discharge.
Biggest bang (spark) for the buck again my opinion is a Crane XR 3000 with their LX 91 coil. A optical trigger system vs magnetic hall effect, 30 plus years with a Allison which later was bought by Crane without failure. JMO's
