Fuse 13 blowing
Old May 3, 2009 | 12:57 PM
offroad21's Avatar
offroad21
Fuse 13 blowing
My 94 blows fuse 13 constantly. I have disconnected the cruse control switch on the master cylinder, the connectors to the steering column, and the turn signals work to all lights meaning the wiring to the brake lights is good.
Anyone have any ideas??? please
Thanks
Russ
Old May 3, 2009 | 01:20 PM
dustybumpers's Avatar
dustybumpers
this is a good thing, get it over to ford for the recall before it burns your truck up
Old May 3, 2009 | 01:50 PM
offroad21's Avatar
offroad21
recall done..I disconnected all wiring to the cruise control, still blows
Russ
Old May 3, 2009 | 04:39 PM
cravej's Avatar
cravej
Did you check the wires for damage? Check the wires going to the fluid level harness by the master cylinder, and check the wires on the brake pedal switch. There must be something shorting out the circuit.
What was the recall for?
Old May 3, 2009 | 04:48 PM
hawgystyle's Avatar
hawgystyle
check for a bad wire under the dash, i had a problem there that blew my fuse 13 for awhile till i rewired the whole truck
Old May 3, 2009 | 05:15 PM
dustybumpers
recall is for wireing harness to cruse control
Old May 3, 2009 | 05:26 PM
dustybumpers
mabe the harness that goes up to the cruse control inside steering whel has rubbed, and is shorting out. I would check out all other possibilities first though, because to check it out you will have to pull the steering wheel, and air bag trucks are no fun to work on
