Adjusting doors
Old May 2, 2009 | 08:18 PM
Unimog005's Avatar
Unimog005
Adjusting doors
I've noticed for some time (about 5 years...lol) that the "gap" between the body and door on my truck is quite narrow in front and a bit wide on the back side....
Seems that "shimming" the hinges where they meet the body would be the solution for this....
Is this correct, or are they adjusted some other way?
and if so....Are there special shims that have to be used, or should I just seek out some washers?
Old May 2, 2009 | 11:14 PM
tlk50's Avatar
tlk50
You might try the apperance and dressup or garage and workshop forums. The body guys hang out there I think,
Tim
Old May 3, 2009 | 05:34 AM
Red69's Avatar
Red69
If you remove the inner door pannel the hinge mounts inside the door have a lot of "slide" available. When you take them loose the height can change also. It takes a few attempts to get it right all around.
Old May 3, 2009 | 06:53 AM
shift1313's Avatar
shift1313
mark your hinges before you start messing around. Like red said, the hinges have a lot of play. they attach to nuts that are allowed to move a certain amount. The hinges mounted to the cab will help you raise the door up/down and take any twist out of it, the ones behind the door panel will let you move the door left/right also allowing the door to twist. I took a paint pen and drew around the hinges before i moved them so i could get back to where it was if needed. Its easy to get things out of whack, the doors arent light.
jetfiremuck
Aerostar
19
May 15, 2026 06:57 AM
ajstephan
Aug 22, 2021 01:05 AM
subliminaltrips
Oct 3, 2009 02:32 PM
sdetweil
Aug 14, 2005 11:45 AM
79CEEJAY
Paint & Bodywork
Nov 1, 2002 01:54 PM
