'84 E350 460 Fuel problem
Old May 15, 2009 | 05:36 AM
Mush's Avatar
Mush
It is behind the passenger kick plate. open the door,look under the dash at the top of the kick plate,and you should find it. there is a button on top of it with a plug end on it. depress the button and tape it in the down position ,or put a jumper wire in the plug end. Mush
Old May 15, 2009 | 08:37 AM
subford's Avatar
subford
It may also be located on the kick board above the passengers feet.
Old May 20, 2009 | 02:20 AM
trucker101's Avatar
trucker101
Question did you get the problem fixed?
I'm having the "SAME" problems with my 85 E350 Motorhome. Did you get it fixed? If so what was the problem?
My posts are
>>Here<< on my problems with the fuel.
Old May 20, 2009 | 07:40 AM
subford's Avatar
subford
My posts are
There is so much bad information in that link I would not know where to start.
I do not think any of the posters over there know what they are talking about as far as your MH.
That is not a fuel pressure regulator, it is a hot gas bypass.
The Oil pressure switch turns off the fuel pumps not the ignition.
And it goes on and on.
Have you read through this link?
Old May 20, 2009 | 08:49 AM
dledm's Avatar
dledm
I know both tank pumps are running and delivering good fuel to start while cranking. The pumps do not run when not cranking. I have tried shorting the oil pressure switch terminals - no luck, but maybe it wasn't making contact. The oil pressure switch fuse is good - I have 12v there with the key on. I wonder if the relay operated by the oil pressure switch is bad (I see this on the wiring diagram). Where is this relay located? I wouldn't think the inertia switch would be bad - nothing has happened to open this.
Old May 20, 2009 | 09:18 AM
subford's Avatar
subford
I do not think that your fuel pump cut-off relay is working. I had another with the same problem and his relay did not have a ground, bad wiring under the relay.
The location of the relay from my only information is "LH corner of dash panel".
Old May 20, 2009 | 11:41 AM
trucker101's Avatar
trucker101
Yes, I just found it last night after doing a google search on the whole forum under fuel & fuel pumps thats how I found your email & posts.
Old May 22, 2009 | 07:03 AM
subford's Avatar
subford
The Fuel cut-off relay is a green relay on the drivers fender.
Old May 25, 2009 | 09:32 PM
trucker101's Avatar
trucker101
Smile
The fuel cut-off relay in under the hood,drivers side,mounted on the inner fender well. Here is a picture for you,just click on it to make it larger.
Old May 25, 2009 | 10:06 PM
dledm's Avatar
dledm
Thanks - I found it, and now I'm looking for it at a dealer.
Old Jun 1, 2009 | 10:53 PM
dledm's Avatar
dledm
Yes - the relay was bad - it's fine now with a new one from Ford!
Old Jul 29, 2010 | 10:42 PM
batmmannn's Avatar
batmmannn
Fuel Relay for the 85 E350 cargo van?
I don't seem to have this set up in the pics. can anyone help me find the fuel relay and cut off switch in my 85? Thanks
85 cargo van econoline 350 carbed 351 V8
Thanks
Old Jul 30, 2010 | 07:28 AM
  #28
subford's Avatar
subford
Thanks
The one in the pics is for a 460 engine with hot fuel bypass and electric fuel pumps and the motor driven six port selector valve. You have none of those.
You do not have a fuel relay or a cut off switch on your 85.
Old Dec 22, 2010 | 10:49 PM
  #29
BeastF-250's Avatar
BeastF-250
No they do not run when you just turn on the key.
That is normal
Unless you know the pumps are running how do you know how much pressure you have?
You would have to put power (jumper power to) on the wire (PK/BK) coming from the starter relay (solenoid) to test the pressure.
No, they will operate when the engine is cranking or if the key is on AND you have oil pressure.
Yes they should be available from a parts house like NAPA.
But it is unlikely that both fuel pumps are bad.
There is a bypass circuit that bypass the oil switch while cranking that is operated by the starter solenoid.
I think these fuel pumps are the same as the fuel pumps used in the 1986-1989 in-tank pumps on the FI trucks and vans. I took a fuel tank from a 1997 FI van and put the tank, pump and all in my 1992 E350 with a 4V Carb. and have been running it that way for 10 years with no problems.
I think they put out between 6-8 PSI as that is what the 4V Carb wants.
Here is a electrical diagram of the fuel system:
thank you so very much... ive been fighting my truck trying to get it running no gas, and i found this and it has solved alot of questions. now all i got to do is get back to my truck and get it running... thank you. Beast F-250
Old Dec 23, 2010 | 12:04 PM
  #30
batmmannn's Avatar
batmmannn
Thanks
I found the problem a ping pong sized ball was in the gas neck where you put the gas in. It seems to be there because of backwash. It was varnish stuck closing off the fuel tank. The tank appeared to be filled to the top at the gas cap but it was not making it into the tank. Truck started beautifully after that. What a pain in the ***.
