Is it standard procedure to drain the torque converter when changing transmission fluid? Is that what the transmission chains like AAMCO do or do you have to tell them?
It definately is not a standard procedure to drain the torque converter with a fluid change. They usually take the pan off, install a new filter, new gasket, refill with new fluid. thats all. you can do it yourself for $20-30.
