Dana 60 swap-NP 205 swap-questions
Well the diff. between the 1350 and 1410 is the same as the diff. between the 1310 and 1330, with that said, back when my pickup was all 78 F150, i broke more 1310s than 1330s, so i upgraded to 1330s with parts i had layin around. they seemed to hold up better than the 1310s.. So with that info i would figure the 1410s are a bit stronger than the 1350s. If i start braking my 1330s in the front Dshaft i will upgrade to 1410s, one reason being i think they are a tad stronger than 1350s, and also i would only have to carry one size ujoint as a spare.
on
To the OP, if you plan on running long tube headers on your truck, you will run into the nasty problem of the front driveshaft and header wanting to take up the same space with a 205 installed.
It's an old pic from back when my truck still had a TTB, but you can see how close the driveshaft is to the header with a 1345, move the output 4" towards the center line of the truck and you'd have serious issues.
byerks
04-27-2015 03:21 PM
Pipelinewelder20
15
10-02-2014 03:56 PM
bigyellerdawg1991
10-27-2013 10:37 AM
TURBO
02-20-2003 05:59 PM
