Backup Camera
Old May 2, 2009 | 02:51 PM
vmark's Avatar
vmark
Unhappy Backup Camera
I want to hook up a backup camera on my 1989 F150 and it is supposed to be wired to the backup lights. Where do I find the correct wire at the rear end of the truck? Thanks.
Old May 2, 2009 | 11:35 PM
F150xlt's Avatar
F150xlt
Here's the schematic for an 88. I would think the 89 would be the same.
Remove one of the rear tail light housings which are held on by 4 Phillip screws.
Pull the tail light housing out and you'll see the bulb holder for the reverse light. The bulb holder should have two wires going to it. A Black wire which is ground and a Black/Pink wire which has 12 volts on it when the transmission is in reverse and the ignition key is in the RUN position.
You can splice into the Black wire for the camera's ground and the Black/Pink wire for the camera's 12 volts.
Old May 3, 2009 | 01:26 AM
trugertha's Avatar
trugertha
if you have wiring for a trailer just hook it up there.
tom18287
6.7L Power Stroke Diesel
Jul 12, 2015 05:12 PM
fireman1965
May 9, 2015 06:01 AM
stevepetro
Aug 5, 2014 04:33 PM
kevgrn114
Jul 31, 2014 07:47 PM
expoman55
May 12, 2014 11:41 AM
