No turn signals !!!
Old Nov 24, 2003 | 05:44 PM
Drake13's Avatar
Drake13
No turn signals !!!
Hello:
I have a 1992 ford f-150. There are no turn signals what so ever now. I have headlights,taillight,parkinglights & brake lights,but no turn signals. Also when I slow down to make a turn when my brake lights are on which ever side I turn my signal on it will take away that same side brake light !!!!!
Any help would be thankful !!!!!
Old Nov 24, 2003 | 06:16 PM
Franklin2's Avatar
Franklin2
I would change the flasher.
Old Nov 25, 2003 | 05:45 PM
Drake13's Avatar
Drake13
Would you happen to know which one the flasher is Franklin?..and is it inside or under the hood ?.....there is nothing to mark which is which on this thing whatsoever.
Thanks !
Old Nov 26, 2003 | 09:34 AM
talisker's Avatar
talisker
The flasher is usually in the fuse block under the dash. At laeast that is where it is in my '69 f-100 and my '95 Tauraus.
Old Nov 26, 2003 | 02:19 PM
macguyver's Avatar
macguyver
It (the flasher) could also be under the dash someplace. The one in the fuse panel is usually the four way flasher. BTW, do the 4-ways work?
Might also be the fuse. Less likely but possible.
thatsrealnice
16
Jul 31, 2020 06:00 PM
Duke78
Jan 17, 2010 04:58 AM
fromm
Electrical Systems/Wiring
Mar 8, 2009 09:04 AM
ranger429
Aug 26, 2003 03:39 PM
