Sponsored by: Real Truck
will tires fit
Old May 2, 2009 | 06:32 AM
zoey's Avatar
zoey
will tires fit
i have a 99 super duty 4x4 ext.cab long bed off road package, my question is will 315-75-16 fit on my truck without a leveling kit i have 285-75-16 they fit with no issues.
Old May 3, 2009 | 05:49 AM
high ho silver's Avatar
high ho silver
Not without some trimming/shimming modifications.
Old May 3, 2009 | 09:50 AM
denvertruckman's Avatar
denvertruckman
Nope, Most likely not even with a leveling kit. That size converts to a 35" tire. Icon leveling says 33's. But I guess with trimming/cutting and a leveling kit.......Maybe. If your going to go with 35'5 lift it. Good luck and show us pics when your done. Oh and if your going that big of a tire. Upgrade the wheels to at least a 18" rim.
Old May 3, 2009 | 11:41 AM
TheHouse's Avatar
TheHouse
I just put 35's on my 03 F250 4x4 /w a Fabtech 5 1/2" lift &
i still had to do some minor trimming at the bumper.
Old May 3, 2009 | 12:08 PM
spinella's Avatar
spinella
i don't want to go against the grain but...my 2000 f350 has 35"x12.5"x16.5 with just a superlifts leveling kit and a little,very little rub. the bumper is trimmed just a little. the difference might be what rims your using.(offset-backspacing). i just took this set-up off. i did'nt want to replace 16.5" tires.
Old May 3, 2009 | 04:45 PM
Fordfanatic4life's Avatar
Fordfanatic4life
4" lift and 315/75/17's on 17x10"s here and still had to trim teh valance a touch to stop a slight rubbage...
mind u mines a F250 not sure if urs is a F350 or not..
ima guess that the tires will rub on the front corners and maybe even on the inner fender well edges to.
Old May 3, 2009 | 04:47 PM
mstiles19's Avatar
mstiles19
they will not fit stock but with a leveling kit the will fit. they will rub your leafs though at lock.
Old May 3, 2009 | 04:55 PM
spinella's Avatar
spinella
i have no leaf spring rub, but again wheel offset is everything.
Old May 3, 2009 | 05:04 PM
conger's Avatar
conger
I installed a leveling kit on mine a couple of weeks ago, but I'm still running with My MT 285/75-16s. I'm not sure whether I'm going with a bigger tire and rim combo yet. One thing that is really noticeable is how much better the ride and control is with a good quality product. The new front springs utilize a 5 leaf pack which is way more compliant than the OEM heavy 2 leaf pack. I'm not going to throw brandnames out there, but all I'll say is buy a good quality kit that comes with new springs, shocks and the appropriate steering components. Steer away from that cheapo add a block stuff. You won'y be sorry you spent the money.
Old May 3, 2009 | 06:42 PM
high ho silver
You also have an F350. To level yours with the 4" blocks your kit had to take you up 2 more inches in the front. Not apples to apples.
Old May 3, 2009 | 06:51 PM
spinella's Avatar
spinella
does the op have a 250? sorry for some reason i thought we were talking 350's
Old May 3, 2009 | 07:47 PM
conger's Avatar
conger
I think some kits are either 250 or 350. The difference is in the back. My 250 needed an add-a-leaf kit to pick up the back since I only had the 2 1/2" block in the rear. The 350 has another leaf already and some have a bigger block.
Old May 3, 2009 | 08:53 PM
mstiles19's Avatar
mstiles19
there is no suspension differences between the 250 and 350 except for the 350 has a 4 inch rear block as opposed to the 250 which has a 2.5 inch block. If you change the block you essentially have a 350.
this means that leveling kits are interchangable between 250s and 350s.
Old May 3, 2009 | 08:57 PM
mstiles19's Avatar
mstiles19
when it comes to lifts you usually get what you pay for. Just because your kit comes with new springs does not mean it is a good kit. Take it from me i have had to replace 2 faulty springs because i got the cheap kit which came with new springs.
Old May 3, 2009 | 10:53 PM
conger's Avatar
conger
That sucks, what kind of kit was it? Did it come with some warranty? That was a lot of work installing, I'd more than a bit irritated if I had to pull it apart again for a busted spring.
