Shift interlock replacement
Old May 1, 2009 | 11:14 PM
Robert_Mays's Avatar
Robert_Mays
Anyone got a procedure to replace the interlock switch on a 2004 console shift. I have searched several times and have only found diagnosis of the problem. I need a procedure to replace the switch. Thanks.
Old May 2, 2009 | 06:03 AM
shorebird's Avatar
shorebird
The switch is located on the side of the transmission.
This is my '01 4R100 trans.
The unit on the right of the photo is the switch. Unplug the harness, un-clip the cable. Remove the mounting bolts. Console or column the procedure is the same.
Old May 2, 2009 | 11:09 AM
Robert_Mays
That does not look at all like what Ford sent me. Mine is a solenoid valve or something.
69ford99
1997 - 2003 F150
13
Jan 24, 2024 04:45 AM
cjpoore
Feb 16, 2019 07:55 AM
lmarkie
1997 - 2003 F150
Jun 9, 2017 12:52 AM
ratstang
1997 - 2003 F150
Oct 8, 2016 11:34 AM
Jo Diesel
Jan 24, 2013 08:54 AM
