2009 F-250 SD Stuck in Park
Hi guys, had to post this here as an absolute last resort. My father has a 2009 Ford F-250 Superduty with the 5.4l V8. Two days ago, he frantically woke me up from a nap because he could not get the truck out of park nor are the brake lights turning on when the pedal is pressed. I instantly thought Shift Interlock, did a quick google search and found that it can be the shift interlock or brake light switch on the brake pedal. I have since then replaced both to no avail as well as checking all fuses. I put a multimeter to the brake light switch connecter and am getting a steady 10.2v.
I am aware there is a bypass switch but that doesn't address the fact that he has no brake lights.
Can anyone provide some insight? Rather not take it to the dealer or an indy as I am a mechanic myself. Thanks guys. I really appreciate it.
Ignore the shifter; Just get the brake lights working. Brake lights are simple, you know all that. They don't even run through the ignition switch.
I think you ought to identify the fuse with some degree of certainty, inspect that, and then jumper the brake light switch. If the truck has cruise control expect that it might have two brake light switches.
if that doesn't solve the problem, you may need a wiring diagram after that.
That is not a valid value, it should be full battery voltage (12-14 volts).
Go check fuse F13 in the under-hood fuse box. If not blown, verify that full battery voltage is present on both fuse test points. If not, there's a problem in the fusebox. If valid voltage, then check for same voltage at gray-red wire at the brake switch, both with the pedal up and depressed. Repeat on the violet-white wire. Report results.
Did some proding around today. Put the multimeter to F13, showing 12v and when the pedal is depressed, it jumps to 20v showing that the brake switch is not the issue here. Put it to F12 which is Brake On/Off Relay Feed and it's showing 10.2v, and does nothing if i pump the brakes. Now what? This is making me mad >.
Still dealing with this problem, my dad got pulled over for no seatbelt and the officer didn't even notice his brake lights don't work lol.
Does the shift interlock need to be installed in a certain way? Put it in neutral, etc, etc.
Or could it be a pressure switch/sensor on the master cylinder? I am referencing this thread for this Message "Trailer Brake Module Fault" ?? - Ford Powerstroke Diesel Forum
He gets the trailer brake module failure all the time now as well.
I figured I’d giving everyone an update incase someone else runs into this probably. My Dad passed away in January of 2018 unexpectedly and never got to see what the problem was and that made me pretty upset and motivated to fix it.
I ended up taking it to a shop for diagnostics. They found that probably a mouse chewed through some of the wiring directly under the fuse box, and that’s what caused the brake pedal to stop communicating with the shift interlock/brake lights. $300 later and it’s all fixed.
Thanks for all the help again guys. It was appreciated.
Pheadrus
11-14-2017 10:54 PM
bigdog71
Escape & Escape Hybrid
11-13-2014 11:28 PM
jsharp921
11-12-2005 07:35 PM
