Negative boost
Old May 1, 2009 | 08:37 PM
throwdown's Avatar
throwdown
Negative boost
Truck ran fine all day. Sat for several hours and when I started it to go home, it reads 1-3 lbs negative boost when I am just cruising. Will jump up when I get on it but then drop right back down. IC boot problem?
Old May 1, 2009 | 08:39 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Has to be the gauge. There is no way you can have negative boost if the engine is running.
Old May 1, 2009 | 09:10 PM
throwdown's Avatar
throwdown
My thoughts as well, but I thought I should ask. I will reprogram in the morning and see if it changes. Thanks
Old May 1, 2009 | 09:25 PM
F350-6's Avatar
F350-6
Where you going backwards
Here's another vote for a gauge issue.
Old May 1, 2009 | 10:43 PM
1996pwrstrk's Avatar
1996pwrstrk
What are you using as a gauge ?
Old May 1, 2009 | 10:52 PM
jeff7825's Avatar
jeff7825
My thoughts exactly. My gauge bottoms out at zero, doesn't go any further down.
Old May 1, 2009 | 11:20 PM
74baja's Avatar
74baja
Correct me if I'm wrong, but since diesels have no throttle body, they can't produce vacuum, right? Isn't that why our trucks have a vacuum pump? So, negative boost (vacuum) must be impossible.
Old May 1, 2009 | 11:50 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Negative boost, do you mean VACUUM? Yes, no throttle body, no vacuum other than the small ~.1 or .2 psi of vacuum at idle
Old May 2, 2009 | 01:01 AM
Kwikkordead's Avatar
Kwikkordead
A clogged air filter will do what you are describing.
Maybe a pigeon got sucked into the intake.
Old May 2, 2009 | 01:52 AM
soutthpaw's Avatar
soutthpaw
I am guessing you have a digital gauge of some sort... Here is a good example of why Mechanical gauges are a better choice....
Old May 2, 2009 | 02:34 AM
throwdown's Avatar
throwdown
Yes, it's a digital gauge and it reads -2 for boost. The truck runs fine with no noises. I assumed it was the gauge but thought I should ask before I tear into it. I guess it's time to go with the A-pillar and manual gauges and ditch this programmer thing for a DP.
Thanks for the replies.
What I mean by no noises is, the normal thrashing machine, 7.3 noises, is all I can hear.
Old May 2, 2009 | 04:32 AM
just another truck's Avatar
just another truck
Sorry For the , But It is still a 4 stroke.. you have a intake stroke.. you should have a vacuum.. Our Turbos push that much air.. even at idle???
Old May 2, 2009 | 06:48 AM
bfife's Avatar
bfife
still plays with trucks
In order to have vacuum, you mut have restriction. the 7.3 has no throttle plate. just as a gas motor has no vacuum at WOT. the diesel has none because their is not enough restriction. I would guess an old NA 6.9/7.3 would develop some kinda vacuum at partial throttle but our turbo takes care of that. Barney
Old May 2, 2009 | 07:16 AM
just another truck
thanks..I would have never guessed..
Old May 2, 2009 | 04:40 PM
PowerstrokeJunkie
Yes, to answer your question the turbocharger does flow enough air at idle to negate the vacuum produced by an intake stroke.
