HELP tranny problems
Old May 1, 2009 | 06:13 PM
milesmac112's Avatar
milesmac112
Exclamation HELP tranny problems
hey guys i have a f250 with a 5.0 and a mazda m5r2 manual trans behind it. hard to go into gear but wont slip out once its in. it does this in most gears most of the time. i was going to try a new clutch because there is not much peddle left. clutch engages almost right off the floor. my question is how much better is a ZF-5 trans than a m5r2? and will the t-case behind the m5r2 blot up to the ZF-5? if it does is there any mods needed to be done like spedo cable and slave cylender and such? any help is great thank you!
Old May 2, 2009 | 06:45 AM
Lazy K's Avatar
Lazy K
Before you dig too deep into a new clutch check the firewall for flexing at the master cylinder and check the pedal mounting for worn bushes.
Old May 2, 2009 | 07:13 AM
plapczynski's Avatar
plapczynski
Mine got a lot smoother after replacing the clutch, master and secondary cylinders.
