Modular V10 (6.8l)
Engine noise
Old May 1, 2009 | 05:24 PM
Insley95's Avatar
Insley95
Engine noise
I have a 99 v10 120k, just recently it started making a noise. It sounds like a lifter slapping in a old pushrod motor. Sitting there at idle, it will tick for a few and then go away, then comes back. Well driving you can hear it loudest just before it shifts with light to no throttle. Please help, I'm about ready to trade this thing in on a PSD. Also motor runs fine doesn't miss. HELP, if I had any hair I would pull it out.
Old May 1, 2009 | 07:04 PM
Fordfanatic4life's Avatar
Fordfanatic4life
exhaust leak would be my guess...
have u checked for broken/lose studs ??
Old May 1, 2009 | 07:26 PM
Insley95's Avatar
Insley95
Been through the exhaust leak thing when I first got the truck, thats NOT it. That is the first thing everyone says, I'am 100% sure.
Old May 2, 2009 | 12:13 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check your plugs!
Old May 2, 2009 | 04:51 PM
dew the thunder's Avatar
dew the thunder
Originally Posted by Krewat
Check your plugs!
I'm with him... sounds like an issue I had.
Old May 2, 2009 | 07:57 PM
Insley95's Avatar
Insley95
dew, what was your situations with your truck. I'm pretty darn close to dealing this thing off. The only thing that confuses me is that the sound comes and goes. It does it all the time, but like I said it stops then starts, very noisy just as the rpm hang before it shifts.
Old May 2, 2009 | 08:22 PM
4DTech's Avatar
4DTech
Well my 2 cents....... Exhaust leak is most common which is why you hear that from everyone. Something I have seen on them also is the timing tensioners get an internal leak, cant hold full tension on the chain at low rpm. higher rpm's ok.... The tensioners run off of oil pressure. Verify where you hear the noise coming from mostly front, sides, rear, under......... Well let us know how you make out..
Old May 2, 2009 | 08:26 PM
Insley95's Avatar
Insley95
The noise seems to come from the pass side more, and almost seems to come right from the center of the engine.
Old May 2, 2009 | 09:16 PM
4DTech's Avatar
4DTech
Hard to tell without looking at it....Sorry man....
Old May 3, 2009 | 01:37 AM
dew the thunder
Well other than my exhaust leak which is now fixed by putting headers on, I had a spark plug on the verge of blowing out. It had become loose and was causing a tick... as well as a miss which most people have not reported with a plug on the verge of blowing out. It is a RPM dependent tick and can be heard at any time regardless of idle, accel, or deccel. Luckily I took it in to get looked at for the miss and they caught the plug before it actually shot out.
Old May 3, 2009 | 06:56 AM
Monster-4's Avatar
Monster-4
Did you check PVC valve? Also check the vacuum lines coming off the throttle body. There is an elbow that tends to crack.
Old May 3, 2009 | 10:25 AM
dew the thunder
Check that as well. My PCV was making all sorts of weird noises and nobody even thought that would be the source. Them things are weird.
Old May 3, 2009 | 10:36 AM
Insley95's Avatar
Insley95
I did check the PCV valve and vacuum lines.
Old May 5, 2009 | 08:25 PM
Insley95's Avatar
Insley95
Work on the pos tonight, it does not make the sound when it's cold. I had to let it idle for about 10 minutes and then rev it up to produce the sound. Any ideas, hope this helps.
Old May 5, 2009 | 09:07 PM
Monster-4's Avatar
Monster-4
Can you get a sound clip?
